multiple serins
Hi
Is it possible for a BS2 to receive 2 separate serins on two
different pins? If so, what's the best way to do it? The application
is a robot which is controlled by 1 serial device but can receive
data from another as well.
thanks
James
thanks
James
Stamp can receive a serin on any pin. I frequently have serins coming in on
five to six pins. Simply address the pin you want to use - very simple.
Sid
will sit and wait forever for a serin unless you use a time option.
Sid
Perfect -- it was the timeout that was causing the problem
thanks alot
James
--- In basicstamps@y..., Newzed@a... wrote:
> For James - just top make sure you know, only one serin at a time.
Stamp
> Sid
anything coming in.
on
