Infrared Sensors
I'm after an infrared sensor which will respond to modulated infrared
light by giving a variable output based on the intensity of the
infrared which is hitting it. I've found sensors which will output
just a high or low in the presence of modulated IR, but none that give
variable output based on intensity. This is not for a proximity
application, as there are variable output IR proximity detectors. But
they appear to work on triangulation methods, not by intensity. So
these will probably be of no use. Does anyone know of such a sensor?
Paul Lugger
__________________________________________________________________
Get your free Australian email account at http://www.start.com.au
Paul Lugger
sensor which will give a variable output relative to the *intensity*
of modulated IR. At the moment I have a Sharp IS1U60. I know that the
IS1U60 will give a low signal in the presence of a certain intensity
of 38Khz modulated IR light. What I want to know is, does it also give
a variable output, related to IR intensity? Or does it have just two
states - high/low?
According to the datasheet the IS1U60 contains an amplifier, limiter,
demodulator and comparator. Maybe one of those limits the output to
being just on or off?
Paul Lugger
IS1U60 infrared sensor. Maybe this will help someone be able to tell
me if the unit is capable of variable output, as oppposed to simply
high/low output.
Paul Lugger
an IR LED to get a variable output. This list does not allow
attachments. HTH..
Leroy
J 1 wrote:
> I have attached a picture of the internal block diagram of the Sharp
> high/low output.
> Paul Lugger
>high/low output.
Search Google for "IS1U60" and the very first URL to pop up is:
http://www.hvwtech.com/dnload/datasheets/is1u60.pdf
In that datasheet you will find the device delivers only an on/off output.
Jim H
the link to it!
Ben
J 1 <plugger2@s...> wrote: I have attached a picture of the internal
high/low output.
Paul Lugger
from the same email address that you subscribed. Text in the Subject and Body of
BEN (TEAM DBR)
http://www.geocities.com/temdbr
Do You Yahoo!?
Get personalised at My Yahoo!.
