Fading Lots of LEDs Seperatley
Hi Guys
Any suggestions on addressing 64 LEDs and setting them all at
different Light Levels to each other under software control?
Has anybody any info in Cross fading of LEDs also?
Cheers for any Help
Chris (UK)
Cheers for any Help
Chris (UK)
stage lights and doing things like cross fading. Of course, you'd need 8
of them, so it might be a little much...
On the other hand, to handle 64 outputs you are going to have to do
something external. Even the BS2P/40 will only handle 32 I/O.
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: christopher_hill2001 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nvD_OBvmzymR231DZBrY9Ca39lEIU4TSXUfRj7xBXKPp_LCCjoDCqrTFchI34GEPoQedXTQGHrrv4APx8ytC]Christopher_Hill@M...[/url
> Sent: Thursday, May 02, 2002 6:39 AM
> Subject: [noparse][[/noparse]basicstamps] Fading Lots of LEDs Seperatley
> Hi Guys
> Cheers for any Help
> Chris (UK)
> from the same email address that you subscribed. Text in the
ports, and only take a 8 bit data in and two addres pins. Combined with a
address decoder, you can probery hook up 96+ Led's
Sent: Thursday, May 02, 2002 6:55 AM
Subject: RE: [noparse][[/noparse]basicstamps] Fading Lots of LEDs Seperatley
> There are a lot of people who use the PAK-V for controlling lots of
> Al Williams
> AWC
> > From: christopher_hill2001 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=x-ggcoEQpB2U3gZfwK_nt8tyB0fN60d-5BC82XVJH0MZZK7pURMOg2ewGKbL7uR2yxRvuAHyUXri9z0bI7jc3AEi]Christopher_Hill@M...[/url
> > Hi Guys
> > Cheers for any Help
> > Chris (UK)
control. We use a DAC for the brightness levels.
Gerald Chustz
Design Engineer
ProSport Displays Inc.
shift registers. The design could easily be upgraded to 64 leds. I'll
post the sourcecode at:
http://www.walrus.com/~raphael/ee/pwm_628c.src
you could maybe make some sort of routine to read commands into the pic
from your stamp.
i hope this helps in some way!
-raphael abrams
