Connecting to C++
Can Anyone please please please please help me with this....I am
really in a deep trouble with thisthing.!!![noparse]:([/noparse]
I got my Basic Stamp to send me a character whenever a light is
blocked on a led...but I am not able to receive this character in my
C++ program....I am on a UNIX system. What I need to do is, i need
to find the time difference between two LED emissions...upon which,
I have made the Basic stamp to send a character to the serial port
everytime the LED emits a voltage. Can anyone help me out on how I
can change the input device on the C++ program from the keyboard to
the serial port ?
PEACE!!
MShrestha
the serial port ?
PEACE!!
MShrestha
You need to know the device name of your serial port
(/dev/tty? Maybe? Some systems uses /dev/cua?). Use open() to open it.
You may need flags like O_NONBLOCK (keeps it from waiting
For carrier detect and O_NOCTTY so that the port can't become a control
terminal).
You can use tcgetattr() to get the current settings of the port. It is
best to modify the existing settings instead of building a termios
structure from scratch. Read the docs on termios - you'll want to set up
a bunch of parameters there. You can use cfsetispeed() and cfsetospeed()
to set the baud rates. I theory they don't have to match, but in
practice...
Use tcsetattr to set device modes. I've heard you may want to use fcntl
to make sure O_NONBLOCK off again, but I've not had any problems.
Then you can use read/write or you could use fdopen or something similar
to wrap the file handle into a FILE * (or use an iostream constructor
that takes a file handle).
In the termios flags, you'll probably want all flags in c_iflag and
c_oflag =0. The c_cflag strucutre requrires you to "merge" your bit size
in:
tios.c_cflag &= ~CSIZE;
tios.c_cflag |= CS8;
You probably also want to set CREAD and HUPCL -- read the man page.
c_lflag has ICANON (line processing - you want this off), ECHO (off) and
ISIG (off).
Other functions:
tcflush (you want to call this before close()).
tcdrain
tcsendbreak
tcflow
Here are some references. Keep in mind that this is one place where
systems vary quite a bit:
http://publibn.boulder.ibm.com/doc_link/en_US/a_doc_lib/files/aixfiles/t
ermios.h.htm
http://www.etek.chalmers.se/~e5arta/LINUX/TERMIOS/termios.html
A search for termios and your OS name would be a good idea.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: manish_shrestha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FkD2rPvj_l1yEmuy9MWU5r2oB1i_EYYx4H4e7OnvyEj4EmPD17FKSS4mKKWmI0JeCKQyrqPWJrBQtkljbEXD3A]manish_shrestha@y...[/url
> Sent: Wednesday, May 01, 2002 7:04 AM
> Subject: [noparse][[/noparse]basicstamps] Connecting to C++
> the serial port ?
> Thanks
> PEACE!!
> MShrestha
> from the same email address that you subscribed. Text in the
problem...I am not able to figure out which port my
circuit is connected to...I tried opening all of the
following ports...and this is what I got:
PORT: cua0
MESSAGE: unable to open /dev/cua0 -: Deviec or
resource busy
PORT cua1
MESSAGE: tty_io.c: process 1214(a.out) used obsolete
/dev/cua1 - update software to use /dev/ttys1
PORT cua2
MESSAGE: tty_io.c: process 1204(a.out) used obsolete
/dev/cua2 - update software to use /dev/ttys2
PORT TTYS0
MESSAGE: Unable to open /dev/ttys0 -: Input/Output
Error
PORT TTYS1
MESSAGE: Unable to open /dev/ttys1 -: Input/Output
Error
PORT TTYS2
MESSAGE: Unable to open /dev/ttys2 -: Input/Output
Error
So which port is my circuit device connected to??
Thanks Bye
Manish
--- Al Williams <alw@a...> wrote:
> What you want is in sys/termios.h
> open() to open it.
> waiting
> terminal).
> of the port. It is
> building a termios
> match, but in
> practice...
> any problems.
> in c_iflag and
> in:
> read the man page.
> ISIG (off).
> Other functions:
> tcdrain
> tcsendbreak
> tcflow
> one place where
> ermios.h.htm
> good idea.
> Al Williams
> AWC
> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nsxO0wR-_lKaFy6ahM25Dj_sG4vQeGb9pE1DNgCljAetB9OUinBWm57c268ECbzDXCxZLPhXqQNBLPqb93ec]manish_shrestha@y...[/url
> with this....I am
> whenever a light is
> to do is, i need
> the serial port
> me out on how I
> > the serial port ?
> > Thanks
> > PEACE!!
> > MShrestha
> Text in the
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
Yahoo! Health - your guide to health and wellness
http://health.yahoo.com
login from holding that port open. This is handled by getty and there is
usually a /etc/conf.getty (or /etc/conf.getty.line). You need to remove
the port you want to use from that file or else you won't be able to
open it.
I'd hook a modem or other serial device to the port and try using a
termial program to talk to it. Then you'd know which port you were on
and that it was free for use.
Al Williams
AWC
port successfully...but wasnt able to read from the
serial port...how do I make the computer wait for the
serial port to send a character before the program
continues? Just like the cin>> we use for input
through the keyboard.
Manish
> I can't tell where your device is connected.
> However, you should disable
> You need to remove
> won't be able to
> open it.
> and try using a
> port you were on
> Al Williams
> AWC
> ignored.
Do You Yahoo!?
