Ltc1298
Has anyone encountered this before? While reading a
value from channels 0 and 1 of the ADC I see 2047 when
input voltage is 2.505 and a reading of 0000 when the
input is 2.506 0001 @ 2.507 and so on up to 2047 again
for 5.01. What gives, I am hoping someone here is
smarter than me (with out a doubt) and can tell me why
this could happen. I have tried 3 chips, same result.
This message was sent through Atlantic.Net Webmail.
Get a free self-installation kit and free activation when you
order business DSL. Visit
http://www.atlantic.net/htm_business/dedicated_dslisdn.html to learn more.
I seem to remember something about this particular
ADC having a single or differential mode of operation.
It sounds as though you are in a differential mode.
http://www.linear.com/pdf/128698fs.pdf
Reading the datasheet on page 9...
"The LTC1298 has a two-channel input multiplexer and can
convert either channel with respect to ground or the difference
between the two."
Look at page 12 under the Multiplexer (MUX) Address on how
to set the LTC1298 Channel Selection.
Beau Schwabe Mask Designer IV - ATL
National Semiconductor Enterprise Networking Business Unit
500 Pinnacle Court, Suite 525 Wired Communications Division
Mail Stop GA1 Norcross, GA 30071
You have a problem with reading the data from the LT1298 - you are losing
the MSB somewhere. The '1298 is a 12 bit a/c convertor which gives counts
from 0 thru 4095. You are seeing counts from 0-2047 and then repeating,
therefore bit 11 is not being read.
Sounds like a fairly simple problem to fix now that you know the cause.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
> between the two."
Unit
Looked at the Datasheet, not much new there. I think I am doing this
stuff right, I may be wrong! Here is a snippet of the code used to
read the 1298:
config var nib
WorkVar var word
AD var word
startB var config.bit0
sglDif var config.bit1
ChanSel var config.bit2
msbf var config.bit3
ChanSel = 0
GOSUB ReadADC
WorkVar = AD
ChanSel = 1
GOSUB ReadADC
WorkVar = AD
ReadADC:
config = config | %1011
LOW ChipSel
PAUSE 40
SHIFTOUT DIO_n,CLK,lsbfirst,[noparse][[/noparse]config\4]
SHIFTIN DIO_n,CLK,msbpost,[noparse][[/noparse]AD\12]
HIGH ChipSel
RETURN
be correct or your read variables might be byte instead of word, or a
combination of all or some of the above problems.
norm
>From: "rhess_1" <rhess@a...>
>Reply-To: basicstamps@yahoogroups.com
>Subject: [noparse][[/noparse]basicstamps] Re: LTC1298
>Date: Wed, 01 May 2002 12:03:30 -0000
> > between the two."
>Unit
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
_________________________________________________________________
Chat with friends online, try MSN Messenger: http://messenger.msn.com
> > between the two."
>Unit
>read the 1298:
>config var nib
>WorkVar var word
>AD var word
>ChanSel = 0
>GOSUB ReadADC
>WorkVar = AD
>ChanSel = 1
>GOSUB ReadADC
>WorkVar = AD
>ReadADC:
> LOW ChipSel
> PAUSE 40
> HIGH ChipSel
> RETURN
Unless something is getting inverted in your code with MSB,LSB I
don't know what to tell you, except it doesn't look like 'lsbfirst'
or 'msbpost' are initializing in your code. Try setting your
'config' to all 1's or try to decipher some of my code I have below
for an LTC1288.
Code Starts Here (MEL Basic StampI compatable)
Symbol PortA = 5 'RA0 through RA4
Symbol TrisA = $85 'PortA Direction Control
Symbol ADC_CLK = 0 'Pin 7 on LTC1288
Symbol ADC_DataPin = 1 'Pin 5 on LTC1288
Symbol ADC_Mode = 1 '0 = diff. ;1 = Single-ended input
Symbol ADC_Data_Out_Bit = pin1 'OUTPUT bit data to pin
Symbol ADC_Data_In_Bit = pin1 'INPUT bit data from pin
Symbol Temp = w0 'Temporary variable
Symbol ADC_Channel = bit0 'W0;Temporary BIT flag
Symbol ADC_Shift_In = b2 'W1.LOWBYTE
Symbol ADC_Data_In_WORD = w2 'B4 and B5
Symbol ADC_1 = w3 'B6 and B7
Symbol ADC_2 = w4 'B8 and B9
Initialize:
Poke TrisA,%11110011:Poke PortA,%00001100
MainLoop:
'Read ADC
ADC_Channel = 0:gosub Read_ADC:ADC_1 = ADC_Data_In_WORD
ADC_Channel = 1:gosub Read_ADC:ADC_2 = ADC_Data_In_WORD
'Debug ADC_1 and ADC_2 for results
goto MainLoop
Read_ADC: output ADC_DataPin:low ADC_CLK:high ADC_DataPin
Poke PortA,%00001000[noparse]:p[/noparse]ulsout ADC_CLK,1
ADC_Data_Out_Bit = ADC_Mode [noparse]:p[/noparse]ulsout ADC_CLK,1
ADC_Data_Out_Bit = ADC_Channel[noparse]:p[/noparse]ulsout ADC_CLK,1
ADC_Data_Out_Bit = 1 [noparse]:p[/noparse]ulsout ADC_CLK,1
input ADC_DataPin:ADC_Data_In_WORD = 0
'for ADC_Shift_In = 1 to 13
for ADC_Shift_In = 1 to 11 '<<- Use 11 instead of 13 to
' "prescale" or effectively
' "divide" the result by a
' factor of 4
ADC_Data_In_WORD = ADC_Data_In_WORD * 2 + ADC_Data_In_Bit
pulsout ADC_CLK,1[noparse]:next:[/noparse]Poke PortA,%00001100:return
what you need is stamp application #4 from nuts & volts.
it deals completely with the ltc1298
email me directly so i get your direct email address and ill send it out as
an attachment to you, or you can goto the nuts & volts web site and download
it from there.
normdoty@h...
Send and receive Hotmail on your mobile device: http://mobile.msn.com
potentiometer setup for testing and all the LTC1298 will read is
from about 2 to 2.5 volts (o to 2047). I am only using one channel
but I get a readings on both. And if I connect the ground to VSS I
get nothing. Any ideas?
Thanks!
There is a most excellent ap note on the parallax site. Look under
downloads, applications. That is what I used.
From: martintreat [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TAHH367qk1XB9wnsyNRsyDsvPCmsrVXhbl7kgfwIBF8BhYhbyAE3BpprkxMjL9nBlPJN5JQ_hB7fAayIZ5WYF5CKRO_P]martin@p...[/url
Sent: Wednesday, May 26, 2004 8:41 PM
Subject: [noparse][[/noparse]basicstamps] LTC1298
I am trying to use a LTC1298 to read a 0-5v signal. I have a
Thanks!
Yahoo! Groups Links
