error correction in a wireless app — Parallax Forums
edited 2002-05-01 11:22 in General Discussion
Hi guys.
I have a wireless application that we have successfully working up
to about 250ft reliably, and as much as 900ft hit and miss.
We are using the Serin command with a Wait(sync) command to watch
for a specific sync. signal from the transmitter.
Is there any better way to do this and have more reliable results?
The unit is a transmitter/receiver pair, so no handshaking is
possible.
Is there a way to possibly bring any and all data in, and do better
analysis or forward error correction to interpret the data?
I know there is signal there, as we are monitoring with a spectrum
analyzer, and if I remove the wait(sync) portion it receives the
data, but its usually somewhat corrupt.
Any ideas welcome.
Thanks in advance
Jody
    edited 2002-04-30 22:30
    At 16:16 04/30/02, moparjody wrote:
    >Hi guys.
    >possible.
    >Any ideas welcome.
    >Thanks in advance
    >Jody
    You didn't mention the baud rate you're using. Lower baud rate may improve
    reliability.
    Also, if a bit of cost is no object, you can use a pair of Packet Terminal
    Node Controllers (TNCs), one between the Stamp and the RF device and one on
    the other end between the RF device and whatever. The TNCs will negotiate
    an errorless transfer of data once it is handed to them by the Stamp or
    device on the other end and all you need to worry about is simple serial
    send receive at RS232 levels. Most TNCs will accept 0 - 5 volts as well as
    true RS232. They typically run 1200 baud, but can be slowed to 300
    baud. Some higher cost units run 9600 baud. You can set the Stamp-to-TNC
    data rate and the TNC-TNC data rate separately, meaning you can communicate
    Stamp to TNC at say 1200 baud and use 300 baud for TNC-TNC to improve
    transfer rate on a marginal path. The TNCs will retry until they get thru
    or time out. You can set them to NEVER time out in which case they try
    forever. The TNCs will perform a full end-to-end acknowledgement that is
    completely transparent to the Stamp.
    Since they contain a fairly large send/receive buffer, you can set the comm
    rate from Stamp to TNC at say 300 baud or 1200 baud and let TNC
    communication remain at 1200 baud.
    A source of such devices is Kantronics, http://www.kantronics.com/
    You can also find these things used on eBay considerably cheaper than new.
    Jim H
    One thing you missed was the fact that this is a 1 direction
    communication. A dedicated transmitter and a dedicated receiver.
    The only way to solve this might be to go with a transceiver set.
    I just thought there might be another way to do this with code. I
    know I am receiving the data. (at 100ft I have -85db of signal
    strenght) and if I remove the sync. command it gets the data. Its
    usually corrupting the sync. bit, so the data isn't getting through.
    thanks
    Jody
    > >Hi guys.
    > >possible.
    better
    > >Any ideas welcome.
    > >Thanks in advance
    > >Jody
    may improve
    > reliability.
    Terminal
    and one on
    negotiate
    Stamp or
    serial
    as well as
    300
    Stamp-to-TNC
    communicate
    improve
    get thru
    they try
    that is
    the comm
    than new.
    > Jim H
