PIC that doesn''t have pbasic
Perhaps Leroy is asking about PIC chips without a
PBASIC interpreter chip on board. These are usually
programmed in Assembler with commercially available
compilers. While the chips are cheaper than the Basic
Stamp, the compilers come at a cost, but more
importantly it is much easier to create and alter
programs in PBASIC than in Assembler. One generally
must redo the program to move between BASICs and
Assembly.
Regards
Bob Pence
--- norman doty <normdoty@h...> wrote:
> there isnt pbasic in any chip.
> you write your program using a simple editor.
> then you compile your program with pbasic.
> then you put the program into the pic with a pic
> programmer.
> process complete, pic now has your program in it,
> not pbasic.
> just the code you wrote, and the routines pbasic
> itself uses.
> normdoty@h...
> >From: Leroy Hall <leroy@f...>
> >Reply-To: basicstamps@yahoogroups.com
> >Subject: [noparse][[/noparse]basicstamps] PIC that doesn't have pbasic
> >Date: Sat, 27 Apr 2002 02:05:35 -0400
> >Here's a simple question,
> >Is there a way to take a program written in pbasic
> and change it to the
> >code required to work in a PIC that doesn't have
> pbasic in it?
> >thanks,
> >Leroy
> >To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> >from the same email address that you subscribed.
> Text in the Subject and
> >Body of the message will be ignored.
> >Your use of Yahoo! Groups is subject to
_________________________________________________________________
> MSN Photos is the easiest way to share and print
> your photos:
> http://photos.msn.com/support/worldwide.aspx
> Text in the Subject and Body of the message will be
> ignored.
Do You Yahoo!?
Yahoo! Health - your guide to health and wellness
http://health.yahoo.com
Assembly.
Regards
Bob Pence
> programmer.
> not pbasic.
> itself uses.
> normdoty@h...
> pbasic in it?
> >thanks,
> >Leroy
> your photos:
> ignored.
Do You Yahoo!?
