PIC that doesn''t have pbasic
there isnt pbasic in any chip.
you write your program using a simple editor.
then you compile your program with pbasic.
then you put the program into the pic with a pic programmer.
process complete, pic now has your program in it, not pbasic.
just the code you wrote, and the routines pbasic itself uses.
normdoty@h...
>From: Leroy Hall <leroy@f...>
>Reply-To: basicstamps@yahoogroups.com
>Subject: [noparse][[/noparse]basicstamps] PIC that doesn't have pbasic
>Date: Sat, 27 Apr 2002 02:05:35 -0400
>Here's a simple question,
>Is there a way to take a program written in pbasic and change it to the
>code required to work in a PIC that doesn't have pbasic in it?
>thanks,
>Leroy
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
_________________________________________________________________
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
normdoty@h...
>thanks,
>Leroy
