Javelin stamp and RF dimmers
Well after alot of research I'm back.
So far the wireless and stamp dimming(PWM) end look good. The one
area that might be a problem is the lighting board to stamp interface.
The board uses a DMX protocol that runs at 250k. The suggestions so
far are to use an UART device to stamp combo then one of Parallaxs'
transmitters. The Javelin specs say that it has a UART onboard. Will
it be fast enough?
Ian Phillips
Shaw Festival
Ontario, Canada
it be fast enough?
Ian Phillips
Shaw Festival
Ontario, Canada
Peripherals, so the upper end speed of the UART is 32K. You'll need a
hardware UART for your project if you want to control it with a BASIC Stamp
or a Javelin Stamp ... or for that matter, any other similar micro.
-- Jon Williams
-- Parallax
In a message dated 4/26/02 3:47:50 PM Central Daylight Time,
iphillips@s... writes:
the same question. One thing you might answer for me is how the UART
chip slows things down for the stamp. If it would help there is a
great description of how DMX works [url=at-http://www.dmx512-]at-http://www.dmx512-[/url]
online.com/packt.html-
Ian Phillips
- In basicstamps@y..., jonwms@a... wrote:
> The Javelin uses a time-slicing technique for its Virtual
(software)
need a
BASIC Stamp
> -- Jon Williams
> -- Parallax
interface.
so
Parallaxs'
Will
