Single pin motor control
At 11:56 AM 4/25/02 -0300, you wrote:
>Does anyone have a tristate circuit to control a motor and direction
>from a single pin ?
>ex: pin as input = motor stop
>pin high = motor forward
>pin low = motor reverse
>Thanks for any help
>ACJacques
Use a DUAL opto-isolator or two single opto-isolators with a 3-resistor
voltage divider. Take the transistor outputs of the opto-isolator(s) to
drive a conventional H-BRIDGE.
LED2 R3
o--|<--o--/\/\
> +5V
STAMP I/O >
o o
o
| LED1 R2 |
o-->|--o--/\/\--o
| R1
o--/\/\
> GND
R1=R2=R3=220 Ohm
Stamp I/O LED1 LED2
Input OFF OFF
LOW OFF ON
HIGH ON OFF
Beau Schwabe Mask Designer IV - ATL
National Semiconductor Enterprise Networking Business Unit
500 Pinnacle Court, Suite 525 Wired Communications Division
Mail Stop GA1 Norcross, GA 30071
>from a single pin ?
>Thanks for any help
>ACJacques
LED2 R3
o--|<--o--/\/\
> +5V
STAMP I/O >
o o
o
| LED1 R2 |
o-->|--o--/\/\--o
| R1
o--/\/\
> GND
R1=R2=R3=220 Ohm
Stamp I/O LED1 LED2
Input OFF OFF
LOW OFF ON
HIGH ON OFF
from a single pin ?
Thanks for any help
ACJacques
genius. Good work Beau!!
Leroy
> >from a single pin ?
> >Thanks for any help
> >ACJacques
> LED2 R3
> o--|<--o--/\/\
> +5V
> STAMP I/O >
o o
o
> | LED1 R2 |
> o-->|--o--/\/\--o
> | R1
> o--/\/\
> GND
> R1=R2=R3=220 Ohm
> Stamp I/O LED1 LED2
> Input OFF OFF
> LOW OFF ON
> HIGH ON OFF
No pulse (high or low doesn't matter), motor stops. 1.5ms pulse at about
20ms intervals is nuetral, 1.0ms pulse servo rotates one way, 2.0ms pulse
the servo rotates in the reverse direction. To use you need to hack the
servo so it rotates continuously.
Another method is to use a serial motor controller, with serial data in
telling the controller what motor or servo to run on one of several or more
channels.
A third method is to use RC hobby Electronic Speed controls (ESC's), you use
the same 1ms - 1.5ms - 2.0ms pulses to control it as well.
From: ACJacques [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Hweqie9XQsGO2-zzjyjx_2c23qKA5220AQ168bXRCa5Q8DTlxnD78HNJ-syXABD8rIwGqc7ONRwbkMmxfifcKA]acjacques@i...[/url
Sent: Thursday, April 25, 2002 9:57 AM
Subject: [noparse][[/noparse]basicstamps] Single pin motor control
from a single pin ?
Thanks for any help
ACJacques
