Variable encoding/compression
Hi everybody, I'm new to this list and to the Stamp.
One of the problems that I see myself possibly encountering in my
Stamp projects is a lack of variables space. Both in size and number.
I guess it would be possible to interace some sort of external memory
chip to the stamp, but maybe there is some way to extend the memory
capabilities of the stamp internally.
One of the problems is that a byte takes up 8 bits and allows 256
states, while a word allows 65536 states while only using up double
the number of bits. It appears that the smaller variable sizes are
less efficient, in terms of bit number versus the capacity of the
variable. This becomes a problem especially if one wants to use many
small variables.
So I was wondering if there are any encoding or compression schemes
which would allow for more efficient use of available variable space?
Perhaps one would be to encode many smaller variables into 1 large
variable.
For example, the word variable 12345. Could be used as an encoding of
the five numbers 1,2,3,4,5. Although this particular scheme is rather
inefficient, there may be some other schemes that someone else can
thing of, along those lines which would work more efficiently. Perhaps
along with some sort of base conversion scheme, maybe to hexadecimal?
I also thought of using lookup tables in the form of DATA statements
as some sort of encoding scheme.
Anyone else have any ideas about this?
Paul Lugger
__________________________________________________________________
Get your free Australian email account at http://www.start.com.au
small variables.
variable.
Paul Lugger
perhaps that will solve the small variable problem. Also groups of pins can
be used as well like 1 pin, 2 pins 4 pins 8 pins and 16 at once into a
single variable. There really is enough variable space if you are a bit
clever in how you go about it..
Mike B.
Sent: Wednesday, April 24, 2002 8:14 PM
Subject: Re: [noparse][[/noparse]basicstamps] Variable encoding/compression
> small variables.
> variable.
> Paul Lugger
