Serial communication to a digital camera
Archiver
Hello,
I just got the protocol specs for the Kodak DC3400 digital camera. I
am wanting to control it with a BS2. I was hoping I might get some
help here. My first question is: can I use the serial connector that
is on the BS2 carrier board? I have read that you can use the serial
connector to talk to a PC with some modifications which leads to my
second question. To start the communication with the camera the spec
says to hold the DTR signal high for at least 470 msecs. After the
connection is made you send 8 bytes of data that contain the command
strings.
Any help/ideas would be appreciated.
thanks
chad
strings.
thanks
chad
camera is true RS232 levels but rather they are most likely TTL levels (+5v)
so you could use any of the I/O pins for comms..
You need to know from the camers specs the baud rate, number of data
bits, and parity to properly set up the Stamp serial port.
Is the spec in a file format or just on paper?? If we had the spec we
could easily determine the easiest way to use the camera. Can you take a
picture witht ehcamera remotely via the serial port?? I might be interested
in that ability for my R/C submarine project.
MIke B.
Sent: Monday, April 22, 2002 8:50 PM
Subject: [noparse][[/noparse]basicstamps] Serial communication to a digital camera
> Hello,
> strings.
> thanks
> chad
carrier boards builtin serial connector. Isn't the DTL used by the
stamp for programming? Anyone ?
The specs have the baud rate and everything else. I have it in pdf
format. If you want a copy then just email my privately.
thanks
chad
--- In basicstamps@y..., Mike Blier <w6ffc@p...> wrote:
> That should be no problem Bear, in fact I doubt the serial interface
in the
levels (+5v)
spec we
take a
interested
stamp for programming? "
This is why I am suggesting using I/O pins for the serial communications
and forget about the DB9 connector. To raise the DTR line simply do this:
HIGH DTR_Pin
pause 470
LOW DTR_Pin
etc, etc
Serial comms with the STamp is really, really easy. Send me a copy of
the .PDF file and I'll take a look and see whats what..
MIke B.
w6ffc@p...
Sent: Tuesday, April 23, 2002 9:11 AM
Subject: [noparse][[/noparse]basicstamps] Re: Serial communication to a digital camera
> I am not sure if I can get the stamp make the DTL high, using the
> thanks
> chad
> in the
> levels (+5v)
> spec we
> take a
> interested
levels(thier
end is actually an Appletalk RS422). They also specified using DTR, but I found
it
worked without it. All the DC20-120 used the same 8 byte command
packets(DC20/5 had parity).
I thought they had dropped serial for USB on all the newer stuff?
> Hello,
> I just got the protocol specs for the Kodak DC3400 digital camera. I am
> wanting to control it with a BS2. I was hoping I might get some help
> here. My first question is: can I use the serial connector that is on
> the BS2 carrier board? I have read that you can use the serial connector
> to talk to a PC with some modifications which leads to my second question.
> To start the communication with the camera the spec says to hold the DTR
> signal high for at least 470 msecs. After the connection is made you send
> 8 bytes of data that contain the command strings.
Mike DeMetz N9GEZ
Elkhart, IN
mailto:n9gez@q...
http://www.elkhart.net/~miked
read on the net, I thought I could just run four wires from the stamp
to the serial cable. VSS, 1 pin for serin, 1 pin for serout using a
22k resitor, and 1 pin for DTR (no resitor ?) . Does that sound
adequate?
The later DC series cameras came with both a serial and USB cable. I
am not sure about the newest models though.
--- In basicstamps@y..., "Mike DeMetz" <miked@e...> wrote:
> I've talked to a DC50 with a STAMP and PIC. It required RS232 driver
levels(thier
but I found it
have to pay for the camera?? I have an Olympus D360L that I am going to
have to see if It has the interface specs available somewhere.....
Anyway, even if the RS232 levels are realy RS232 you can still use either
direct connection to the camera by simply inserting a 22k resistor in series
with the data pin FROM the camera. TTL levels from the stamp TO the camera
should still work just fine.
If you are really worried about it you can use a MAX232 chip that will
convert the RS232 level to TTL or if all else fails you could use the serial
port (pins 1 -4) on the stamp.
Mike B.
Sent: Tuesday, April 23, 2002 11:19 AM
> What did you have to do to get RS232 driver levels? From what I have
> adequate?
> levels(thier
> but I found it
on your camera. Someone already has a stamp working with it. Go to
http://www.parallaxinc.com/html_files/customer_apps/apps_digitalcamera.htm
He uses a different model, but according to photopc.sourceforge.org
his camera has the same protocol as yours. photopc.sourceforge.org
has the protocal for cameras that use the sierra chip which I think
includes the D360L
> Wow! Am I impressed with the interface of this camera!! What did you
use either
in series
camera
a Canon S20, and I would like to do some remote serial interfacing to
it.
Allan
Date: Tuesday, April 23, 2002 2:28 pm
> You can get a refurbished one on kodak.com for $249. You are in luck
> includes the D360L
Thanks for the heads up.
Now if I can only figure out a working periscope for the camera to look
through.. Hmmm.......
Mike B.
Sent: Tuesday, April 23, 2002 1:28 PM
> includes the D360L
> use either
> in series
> camera
http://sourceforge.net/softwaremap/trove_list.php
Mike B.
Sent: Tuesday, April 23, 2002 2:48 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Serial communication to a digital camera
> Has anyone seen the serial protocol for a Canon digital camera? I have
> it.
> Thanks
> Allan
> From: bear_phillips <bear_phillips@y...>
> > includes the D360L
including the Canon S20. If you ask on their mailing list, I am sure
someone can get you the protocol. That is how I got mine.
--- In basicstamps@y..., aldobler@s... wrote> Has anyone seen the
> it.
> Thanks
> Allan
and found many types of max232. Can anyone give me some info on what
all I need to do rs232 communication. Which max232, any other parts
needed? I a sample schematic?
What I am trying to do is set the DTR high, then send 8 bytes in hex
"7C,00,00,00,00,00,00,1A" at 9600 baud 8 bit, no parity, 1 stop bit.
Can anyone take a quick look at my code and see if it looks right.
high 3
debug "high",cr
sleep 5
BAUD_MODE CON 16468
serout 0, BAUD_MODE ,[noparse][[/noparse]$7C,$00,$00,$00,$00,$00,$00,$1A]
Pin3 on BS2 connects to pin 4 on the serial connector
Pin0 on BS2 connects to pin 2 on serial
VSS on BS2 connects to pin 5 on serial
thanks
chad
requires no caps (but costs more than a max232 + 4 caps).
You can find the schematics in the data sheet at www.maxim-ic.com. You
might consider http://www.al-williams.com/awce/rs1.htm which is easy to
use with a breadboard or even to integrate into a permanent design.
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: bear_phillips [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6ueUVQD2w9I1NyjdOj3J_UMth8DRDhFTQS-XwrS9FL69dPAdjiETjdb0uidMSXeNVZcDDKEKcRdpxbU-2LmP]bear_phillips@y...[/url
> Sent: Tuesday, April 23, 2002 11:10 PM
> Well no luck so far. I am going to get a max232. I looked
> at Jameco, and found many types of max232. Can anyone give
> me some info on what all I need to do rs232 communication.
> Which max232, any other parts needed? I a sample schematic?
> in hex "7C,00,00,00,00,00,00,1A" at 9600 baud 8 bit, no
> parity, 1 stop bit.
> high 3
> debug "high",cr
> sleep 5
> BAUD_MODE CON 16468
> thanks
> chad
Tony Wells
Sent: Tuesday, April 23, 2002 4:50 AM
> Hello,
> strings.
> thanks
> chad
Maxim/Dallas will send free samples of the max232, max232a, and max233
(as well as a large assortment of other Dallas and Maxim parts). I
have found their extemely liberal samples policy to be very usefull
when prototyping out something that requires only one or two pieces of
a part that you would otherwise have to order from someone who has a
minimum purchase. Check them out on the web at:
www.dalsemi.com
Dallas Semiconductor and Maxim have merged, so they have the same
website now. Just follow the "Samples and Literature" link on their
home page. You could easily combine the freebie parts from Maxim with
Al's SR-1 breadboard kit to make an RS-232 interface for your Stamp for
less than 10 bucks...
peter
Date: Wednesday, April 24, 2002 8:11 am
Subject: RE: [noparse][[/noparse]basicstamps] Re: Serial communication to a digital camera
> A max232 requires 4 1uF caps. A max232A requires 4 .1uF caps. A max233
> might consider http://www.al-williams.co which is easy to
> Al Williams
> AWC
Below is the take picture code(True9600).
'serout TX,84,[noparse][[/noparse]$7C,$00,$05,$00,$00,$00,$00,$1a]
'serin RX,84,[noparse][[/noparse]Stat1]
'serin RX,84,[noparse][[/noparse]Stat2]
The last 2 lines just wait and eat the command OK and command complete bytes
sent by the camera.
> Well no luck so far. I am going to get a max232. I looked at Jameco, and
> found many types of max232. Can anyone give me some info on what all I
> need to do rs232 communication. Which max232, any other parts needed? I a
> sample schematic?
> "7C,00,00,00,00,00,00,1A" at 9600 baud 8 bit, no parity, 1 stop bit. Can
> high 3
> debug "high",cr
> sleep 5
> BAUD_MODE CON 16468
