Serin & serout — Parallax Forums
Serin & serout
edited 2002-04-22 16:05 in General Discussion
Hi All,
I wrote a C program to send commands to the stampII.
The stamp should then respond to the commands. For
example C program sends "*SN\r\n" the stamp should
reply with "SN=12345".
Ok now the problem is that the stamp seems te echo
back the command before the reply. It first sends
"*SN\n" and then "SN12345". (I just want the
"SN12345")
I am using pin 16 for both serin and serout. Why
does this happen? Will it always happen?
How can I prevent this.
Code:
Serial Data "SN12345",0
Start Var Byte
Init :
SerIn 16,16468,[noparse][[/noparse]Str Serstr\10\cr]
if SerStr(0) <> "*" Then INIT
Gosub Choice
Return
Choice :
If SerStr (1) = "S" Then ShowSerial
If Serstr (1) = "V" Then ShowVersion
Return
Both ShowSerial and ShowVersion just routines that
sends a string out with Serout.
But before the program can get to choice the "*S\r\n"
is echoed back.
Thanks for You Help
Danie
__________________________________________________
Do You Yahoo!?
Yahoo! Games - play chess, backgammon, pool and more
http://games.yahoo.com/
    I think the problem is not in the code but in the connections. It sounds like
    you have the data in and data out lines from your PC both going to the stamp's
    I/O 16. If so, your PC is probably talking to itself. Test this theory by
    removing power to the stamp. I bet you get the same "echo" behavior. My
    suggestion on a fix is to use any of the I/O pins 0-15 as the input (with an
    in-line limiting resistor as recommended in the manual). Then use 16 as your
    output, as it comes closer to the 232 levels. Good luck.
    Clark Hughes
    didv wrote:
    > Hi All,
    > "SN12345")
    > Code:
    > Start Var Byte
    > Init :
    > Gosub Choice
    > Return
    > Choice :
    > Return
    > is echoed back.
    > Thanks for You Help
    > Danie
