Outs ??
Archiver
I have been programming the BS2 for a while and cannot really find
much details on how to use OUTS. I am dividing the 16 I/O's into
two group 0-7 and 8-15. I want to manipulate these two groups of
pins separately, ie. send the send 0010001 (to turn pin 1, and pin
5 on), and send another command (don't know how) to turn on pin 10
and pin 14.
How can I do that? There is very little about this in Scott Eward's
book, and couldn't find anything nor examples in the manual. could
anyone explain and preferrably with an example?
Many thanks..
Al
and pin 14.
Many thanks..
Al
will set all the pins at once.
You can do this with a decimal, hex or binary value, but binary is easiest
to understand. Here is an example in binary:
OUTS = %0100100000100010
This will turn on pins 1,5,11 and 14 as outputs. Just remember the numbering
scheme goes from right to left and is 0-15 -- it does not start with 1.
Keep in mind you can also address pins 0-7 and pins 8-15 separately. Its a
bit confusing because you reference them to their relative position in
control byte and not their actual pin value -- here is how it works:
OUTS looks like this 15-14-13-12-11-10--9--8--7--6--5--4--3--2--1--0
OUTL fits like this xx-xx-xx-xx-xx-xx-xx-xx-7--6--5--4--3--2--1--0
OUTH fits like this 7--6--5--4--3--2--1--0-xx-xx-xx-xx-xx-xx-xx-xx.
Here is how it works in your example
OUTL = %00100010
will do what you want for turning on pin 1 and 5, and
OUTH = %01001000
will turn on pins 11 and 14.
> and pin 14.
How come non of this is in the manual, and more surprisingly not in
Scott Edward's book?
Al
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> Writing a value to OUTL will set pins 0-7 and OUTH will set pins 8-
15. OUTS
easiest
numbering
with 1.
separately. Its a
position in
works:
0
1--0
xx.
> OUTL = %00100010
> OUTH = %01001000
find
pin
10
> > and pin 14.
Eward's
could
of input (INS) and output (OUTS) variables, and the various methods of access
(bit, nibble, byte, word).
Scott does an excellent job with his books and makes a deliberate choice not
to repeat information from other manuals. That said, there is a detail
discussion of the Stamps I/O structure and its mechanics on page 77.
-- Jon Williams
In a message dated 4/21/02 9:21:34 PM Central Daylight Time,
brownstamp@y... writes:
have some basic microprocessor knowledge. I think I saw it explained in
another manual and thats how I figured it out.
> Many many thanks, it is perfectly clear now.
> 15. OUTS
> easiest
> numbering
> with 1.
> separately. Its a
> position in
> works:
> 0
> 1--0
> xx.
> > OUTL = %00100010
> > OUTH = %01001000
> find
> pin
> 10
> > > and pin 14.
> Eward's
> could
in chapters 2 and 3 of my book. I don't have a copy of the Edward's
book, but I'd be very surprised if it wasn't in there...
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: brownstamp [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=z9sQYBsYjnPg2U51peMqFWBaRb-t_ag-4MY26zp0CRhfz3ZnLK0wEPp4vygqW9vmH0-h-FEb0KO6vsOh]brownstamp@y...[/url
> Sent: Sunday, April 21, 2002 9:19 PM
> Subject: [noparse][[/noparse]basicstamps] Re: OUTS ??
> Al
> 15. OUTS
> easiest
> numbering
> with 1.
> separately. Its a
> position in
> works:
> 0
> 1--0
> xx.
> > OUTL = %00100010
> > OUTH = %01001000
> find
> pin
> 10
> > > and pin 14.
> Eward's
> could
> from the same email address that you subscribed. Text in the
viewing the electronic copy, jump to page 49 on your Acrobat reader.
I think the problem was he did not understand how OUTL and OUTH were related
to OUTS. This is not real obvious if your new to processors.
> Look at table 4.2 in the Stamp manual (pages around 46 or 47). Its also
