again button command
Hello stampers
When I use multiple button commands to contol multiple inputs, do I have to
define a dedicated "workspace variable" for each button command or can they
share the same variable.
Michel
Met vriendelijke groetjes,
> Michel De Meester
> Biotechnisch Onderhoud
> Universitair Ziekenhuis Antwerpen
> Wilrijkstraat 10
> 2650 Edegem - B
> tel: ++32 (0)3 821 36 47
> e-mail: michel.de.meester@u...
Michel
> Michel De Meester
> Wilrijkstraat 10
> 2650 Edegem - B
that will let you scan and debounce four inputs (the program assumes inputs
are active low -- remove the tilde [noparse][[/noparse]bitwise invert] operator if your inputs
are active high).
-- Jon Williams
btnsIn VAR InA ' four inputs, pins 0 - 3
btns VAR Nib ' debounced inputs
x VAR Nib ' loop counter
GetButtons:
btns = %1111 ' enable all four inputs
FOR x = 1 TO 10
btns = btns & ~btnsIn ' test inputs
PAUSE 5 ' delay between tests
NEXT
RETURN
In a message dated 4/19/02 8:45:34 AM Central Daylight Time,
Michel.De.Meester@u... writes:
