LCD leads -- how long, how vulnerable?
We are using a small LCD in the electrically noisy environment surrounding my
radio control transmitter. The
idea is to clip the LCD to the transmitter's antenna, to put it at eye level, or
a little below, while the xmtr is
in use.
Or is this a really bad idea?
In my experience r/c transmitters are pretty noisy. If you put a broadcast
receiver next to a radio control
transmitter, you can usually hear quite a hum. (In fact this is a common r/c
troubleshooting field technique to
check for signal).
The leads to the LCD would necessarily be pretty long, maybe a couple of feet.
Is this going to work? Would a
coax help, or some other system of shielding? How robust is the signal from my
stamp to the LCD?
Thank you for your insights, Michael
in use.
check for signal).
stamp to the LCD?
