Fwd: basic stamp timing Q''s
Below is a note that I got from one of my colleagues.
What kind of timing resolution/repeatability can he expect?
Is there an add-on that would give more precise timing?
What's the FASTEST stamp (for shortest resolution)?
thanks
>Here's what I want to do with a basic stamp. I want to replace my aging
>Apple II flash controller with something newer and more portable. The
>controller works like this:
>1. It reads digital inputs from various transducers (acoustic, light,
>contact closure)
>2. It has 16 digital outputs to control flash units or other devices
>(solenoid, for example). I just need 5-volt output signals. I have
>buffer circuits available between the controller and the devices.
>3. It generates time intervals between input and first output as well as
>between successive outputs. The time intervals are selectable to a few
>microseconds. The accuracy is about a microsecond.
>thanks,
\ / \ / \ N / \ C / \ S / \ S / \ M / \ / \ /
Chuck Britton Education is what is left when
britton@n... you have forgotten everything
North Carolina School of Science & Math you learned in school.
(919) 286-3366 x224 Albert Einstein, 1936
thanks
>contact closure)
>thanks,
