Comparison speeds...
Archiver
Hello Stamp Guru's...
Is it faster to compare the lower nibbles of 2 bytes than it is to compare the
whole 2 bytes, for example:
Is...
if byte1 <> byte2 then DoSomething
slower than...
if byte1.lownib <> byte2.lownib then DoSomething
I have to compare chunks of 3 bytes in a table of 10000 bytes in an Eeprom, so
it gets a bit tedious.
Also, how much faster is the I2C command in the bs2p than the shiftin / shiftout
routines when used with a bs2sx.
Any help appreciated...
Thanks in advance,
Chris
Is...
slower than...
Thanks in advance,
Chris
>compare the whole 2 bytes, for example:
>Is...
>slower than...
The guruvy way to find out is to ask the ultimate authority, the
stamp itself. With stopwatch in hand, try the following program:
x var word
y var byte
for x=1 to 10000
if y.byte0<>y.byte1 then gonext
toggle 1
gonext:
next
Then substitute y.nib0 and y.nib 1 in the decision, and compare the
times for 10000 trips around the loop. (Or measure the frequency on
p1 with a counter) My guess is that it will be pretty much a wash.
The nib form may take slightly longer, because the address of a nib
in memory is longer than the address of the byte. What that means is
that the interpreter has a slightly longer instruction to read out of
the eeprom. There are 32 bytes in the RAM space, and 64 nibs, so it
takes a 6 bit address versus a 5 bit address. However, the stamp
interpreter stores powers of two like 0,1,2,4 in an especially
compact format, so you may find dealing with x.nib3 to be different
from x.nib2. There are always these fine points of difference
depending on where the variable happens to fall in memoryh. But in
the main, the speed of the Stamp depends on the number of bits that
the interpreter has to read from the eeprom prior to executing the
instruction.
>Eeprom, so it gets a bit tedious.
>shiftin / shiftout routines when used with a bs2sx.
In general, I2C is a slower protocol than SPI (Shiftin/out). I think
on the BS2p the I2C command can have several parameters, and it takes
time for the interpreter to read them out of eeprom. I have not done
any specific tests though.
>Thanks in advance,
>Chris
HTH.
-- Tracy
way.
Chris
