Pulsin questions and incline meter
Archiver
I'm looking at making a bicycle speedometer with a BS2. I plan on having
a reed switch on the fork activated by a magnet on a spoke. It looks
like the pulses have to occur in less then .131 seconds for the pulsin
command to pick them up. This would be 34mph! just as a starting point
(not very good for a bicycle). So I am looking for a way to pick up
slower pulses with a stamp, my goal is a range of 1.6sec/rev-.08sec/rev
with a lot of steps between.
The pak-7 for Al Williams might fit the bill but I couldn't really see
the range that it handles. I also liked the multichannel properties of
this IC as in the future I might want to add cadence (pedal RPMs) and HR
to the list of functions. There may be better solutions than this but
alas I am a beginner at this.
Also I would like to implement a incline meter to detect the steepness
of hills. There were recently some posts about a similar topic but it
seemed the incline meter took a back seat to other solutions. Is there a
good solution for this? A bicycle is subject to a lot of different
accelerations so it seems like getting an accurate reading from a steel
marble in a tube could be challenging.
TIA,
Dan
TIA,
Dan
The analog devices ADXL202 is an extremely small dual axis +/- 2g tilt sensor
that is very easy to interface with the stamp. I've done it, and I've seen
application hints, etc., indicating that others have done it as well. Look at
the following:
Analog Devices web site
Google search for ADXL202 and "basic stamp"
Search the archives from this list.
Good luck.
Clark Hughes
Daniel Stark wrote:
How about using more than one magnet? How about using an optical couple
and counting the number of spokes?
leroy
> TIA,
> Dan
More than one magnet might work, they would have to be as close to
even-spaced as possible I still would like to find a different solution
so that HR and Cadence can be done. The optical is also an intriguing
idea so long as you don't switch wheels to one with a different spoke
count.
-Dan
On Monday, April 15, 2002, at 04:18 PM, Leroy Hall wrote:
> Dear Dan
> leroy
>> having
>> HR
>> there a
>> TIA,
>> Dan
>> and Body of the message will be ignored.
LCD?
If you want really cool and have some bucks to toss, you could use a GPS
receiver, which would give you a speed and altitude output and allow you to
calculate distance and incline.
> count.
> >> having
> >> HR
> >> there a
Hi Dan,
Check out this URL for some info on tight timing loops in program code:
http://www.emesystems.com/BS2speed.htm#longpulse
There are also links to other external timer chips for you to consider.
-- Tracy
For what it's worth:
Before bike speedos were cheap, we built one using an opamp, counters, and a
display chip. The sensor was made from an old relay coil, magnetically
biased with one of those Radio Shack toroidal magnets. It was mounted on a
fork and counted spokes on one side of the wheel. Since we used it on two
bikes, the divide ratio had to be set with a switch since each bike had a
different number of spokes. It has much better resolution and accuracy than
the commercial units which receive only one or two counts per revolution.
It would be easier to implement today using a Stamp.
Good luck,
Ray McArthur
