Sensing RPM on a small gas engine (Briggs&Stratton 8hp)]
might want to put voltage divider on ignition primary
richard
Sent: Monday, April 15, 2002 10:58 AM
Subject: [noparse][[/noparse]Fwd: Re: [noparse][[/noparse]basicstamps] Sensing RPM on a small gas engine
> Used to have a "spark detector" that was used for troubleshooting
> ignition problems. I think it had a transistor with a floating
> base at the end of a two conductor cable. The high voltage
> from the spark would "fire" the transistor when it was close enough
> to be affected by the electromagnetic pulse. That would then pull
> a resistor down. The thing worked pretty well and didn't have to be
> in contact with the high voltage plug wire.
> HTH
> Gary
richard
> HTH
> Gary
