Power up problem. — Parallax Forums
Power up problem.
edited 2002-04-19 12:50 in General Discussion
Hi guys, I have a BasicStamp 2 that I'm using as a converter
for an automotive sensor prototype. The Stamp recieves pulse width
modulated data and converts it to ASCII then sends to a laptop.
IF the power to the laptop is present before the STAMP power
then the Stamp doesn't run. If the Stamp is powered first everything
is fine. Any help???
I assume I'll need an isolated driver or something like that...
Part numbers?? Schematics??
Gary
    edited 2002-04-17 17:59
    Apparently no one else has ever had this problem????
    > Thanks,
    > Gary
    edited 2002-04-18 16:55
    Maybe you could share your stamp program?
    Leroy
    > > Thanks,
    > > Gary
    edited 2002-04-19 01:12
    Hi Gary,
    Try something like this:
    http://focus.ti.com/docs/prod/productfolder.jhtml?genericPartNumber=TL7705B
    This is a voltage supervisor with a programmable delay that you could use as
    a "reset" to the stamp. The part is available in PDIP if you are opposed to
    surface mount devices. You can get samples from TI or buy from Digi-Key
    (p/n 296-3242-5-ND)
    Tom
    Sent: Wednesday, April 17, 2002 11:59 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Power up problem.
    > > Thanks,
    > > Gary
    edited 2002-04-19 06:24
    Hi Gary,
    When a system locks at power up, the problem is often a phenomenon
    called SCR latchup. The outside source (your laptop) turns on first
    and drives a large current (>~20 ma) into an input pin of the Stamp
    (i.e. an input pin on the PIC chip on the stamp). The Stamp stays
    locked when you apply power to it. No function. Bad. Also possibly
    damaging if the current is too too high.
    The simple fix for this problem is to put a resistor between the
    source (the laptop) and the Stamp chip input, to limit the current to
    10 milliamps or less. A 470 ohm resistor is usually sufficient.
    Maybe that is the problem. Could be something else.
    -- Tracy
    (P.S. Probably everyone in EE has been bitten by this problem at one
    time or another. FYI, the lockup is actually a side effect of the
    construction of integrated circuits, the substrate diode, which at
    high currents becomes a "silicon controlled rectifier", with positive
    feedback that keeps it in a locked state. )
    > > Thanks,
    > > Gary
    Thanks Tracy, I'll try the limiting resistor. Makes sense.
    Gary
    --- In basicstamps@y..., Tracy Allen <tracy@e...> wrote:
    > Hi Gary,
    first
    possibly
    to
    > -- Tracy
    one
    positive
