current detection
I am looking for a solution to meaure current in 3 different circuits. Is there
a clever design for a current sense circuit for the
BS2? I need to be able to measure up to aproximatly 300A on 1 circuit. 200 on
another and aproximatly 10 on the third circuit. I
have considered a D/A and a .1 Ohm resistor. My problems so far have been
voltage drop @ 300A on a 12V and the size of the resitor
to handle that much wattage. I would also like to read the a voltage as well...
Is there a simple "multimeter" IC? Any ideas would
be appreciated.
MH
be appreciated.
MH
might be a possible answer. You might find some of this size in
electronics surplus houses. If they are DC, you can use a piece of wire
known gauge and size and calculate the resistance from the wire
tables.. Back before mutimeters would read in the 20 amp range, I made
a shunt to measure the current from the heater motor on my car using a
piece of 12 gauge solid copper wire about 20 feet long.
HTH,
Leroy
there a clever design for a current sense circuit for the
well... Is there a simple "multimeter" IC? Any ideas would
> be appreciated.
> MH
They have AC and DC hall effect current sensors for up to 300 amps. I've played
with 50 amp unit on DC currents and it worked great.
Hank Hagquist
Team RCV - http://teamrcv.com
Hobby Talk - http://hobbytalk.com
Sent: Sunday, April 14, 2002 11:07 PM
Subject: [noparse][[/noparse]basicstamps] current detection
> be appreciated.
> MH
voltage... Are you aware of any digital volt meters? I
would like a volt meter that i could read from the BS2 digitally without much
work. Any ideas are appreciated. Thank you for your
assitance. It is greatly appreciated.
MH
Sent: Sunday, April 14, 2002 10:51 PM
Subject: Re: [noparse][[/noparse]basicstamps] current detection
> Try http://www.ampsense.com
played with 50 amp unit on DC currents and it worked
great.
> Hank Hagquist
> From: "Michael Hendricks" <mjh80@b...>
the
on another and aproximatly 10 on the third circuit. I
resitor
would
> > be appreciated.
> > MH
digital volt meter chips that are available, but I'm sure someone here would
know of some if they are available.
Hank Hagquist
Sent: Monday, April 15, 2002 12:06 AM
> This looks great. I am assuming to read these i would need to read the output
> MH
> From: "Hank Hagquist" <hankster@h...>
> great.
> > Hank Hagquist
> the
> resitor
> would
> > > be appreciated.
> > > MH
