Why is PBASIC so clunky?
Archiver
Something that has bugged me from day-1 about PBASIC.
How come it lacks basic and obvious programming structure constructs,
stuff like:
if/then/else
case
while/wend
repeat/until
begin/end blocks
I mean, this stuff would be trivial to add to the compiler, it ought
to be a couple of days work at most, and it would make programs so
much easier to write and to read -- and isn't that the point of
educational use of basic stamps anyway? It's hard to write good code
that others can understand when it contains a bunch of gotos.
Dartmouth Basic, back 30 years ago, had many of these constructs.
PBASIC ought to as well.
Best
R
stuff like:
if/then/else
case
while/wend
repeat/until
begin/end blocks
Best
R
trim by design. This allows it to be very efficient, even if a "high level"
language.
That said, we recognize that most of our customers are coming from modern
desktop BASICs and are accustomed to the programming structures you
indicated. So, we have, in fact, started on a compiler update that will
bring these structures to our BASIC Stamps. You are seriously wrong,
however, in that the update will take just a couple of days. That kind of
work might be fine for our would-be competitors, but not for us. We will be
as diligent as possible in our approach and it will take more than a couple
of days. We typically spend a couple of months internally testing compiler
changes after we think it's done and even with that there are occasional
problems.
-- Jon Williams
In a message dated 4/14/02 2:43:07 PM Central Daylight Time,
trebor@a... writes:
> stuff like:
> if/then/else
> case
> while/wend
> repeat/until
> begin/end blocks
Don't change a thing in the way you guys develope ANYTHING. I keep
coming back after try the Brand X (hint) devices and after much hair pulling
I throw the STamp back in the circuit and keep on trucking..
By the way, two of your stamp 2's are about to control a 11' 3" long R/C
submarine...
Mike B.
Sent: Sunday, April 14, 2002 1:25 PM
Subject: Re: [noparse][[/noparse]basicstamps] Why is PBASIC so clunky?
> PBASIC was designed to be very close to its core micro and, as such, is
very
level"
> language.
be
couple
compiler
> problems.
> -- Jon Williams
> trebor@a... writes:
> > stuff like:
> > if/then/else
> > case
> > while/wend
> > repeat/until
> > begin/end blocks
I forgot to mention that we do have another product near release that
includes fully structured programming: the Javelin Stamp. It programs in a
subset of Sun's Java but is as easy to use as a BASIC Stamp (and will fit in
the same socket).
Details at: www.javelinstamp.com
-- Jon Williams
In a message dated 4/14/02 4:30:29 PM Central Daylight Time,
w6ffc@p... writes:
> Jon:
> submarine...
>language.
With all due respect (and I'm not trying to pick a fight here),
efficiency issues for basic constructs (like if/then/else or
while/wend for example) have little or nothing to do with the
constructs themselves, and everything to do with the efficiency of
the compiler and the structure of the target operation set (which I
would assume is some sort of icode in the case of the Basic Stamp).
That's good news.
You will note that I said it would only take a couple of days to
*add* the features, I have no problems with you taking the time to
test then properly. I've written more than a handful of compilers in
my time, so I don't think I'm too far off in my estimate.
Please don't get the impression I'm trying to get on Parallax's case,
it was not intended that way. I'm having a lot of fun playing with
the SX2, it reminds me of the days of my youth when clock speeds were
measured in kilohertz and one had to code with care and elegance.
Just managed to get the little beast to simultaneously trigger and
poll 8 ultrasonic sensors, compute the evasion trajectory for
multiple detected objects and get >10 updates a second. Would like
to run it faster, but it's somewhat of trial and error to find out
what code constructs run the fastest. Is there any doco out there
about operation speeds?
Best
R
faster than IF-THEN and may help. Also, using READ (from EEPROM table)
instead of LOOKUP seems to work faster in programs I've taken the time to
analyze.
-- Jon Williams
-- Parallax
In a message dated 4/14/02 6:03:17 PM Central Daylight Time,
trebor@a... writes:
you could build this kind of functionality into the editor, as a sort of a
preprocessor. One of the most obnoxious things IMO about the BS2 basic is
the conditional branching approach. It reminds me strongly of my days of
programming the 6502 microprocessor without an assembler, and the result
is that to do anything vaguely complex you have to fill the code base with
so many unnecessary labels that it becomes unreadable. With a little
logical structure (gosub on condition, execute complex statement on
condition, perhaps an argumented function approach) it could look a heck
of a lot cleaner, and I Think most of it could be in the editor so the BS2
itself wouldn't see a change.
On Sun, 14 Apr 2002, Robert Woodhead wrote:
> >PBASIC was designed to be very close to its core micro and, as such, is very
> >language.
> That's good news.
> Best
> R
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
are you guys planning to 'fix' I2CIn and I2COUT commands so they can
take null address in order to use it with non-memory products (LCD
displays, etc.
Arthur
such, is very
a "high level"
> language.
modern
will
<snip here>
> -- Jon Williams
hold timeout to give "intelligent" I2C devices more time for internal
processing.
-- Jon Williams
-- Parallax
In a message dated 4/15/02 10:49:04 PM Central Daylight Time, m5art@y...
writes:
Sent: Sunday, April 14, 2002 3:23 PM
Subject: [noparse][[/noparse]basicstamps] Re: Why is PBASIC so Clunky?
very
level"
> >language.
> That's good news.
> Best
> R
