Unresponsive BS2SX
I'm not too experienced with Basic Stamps, but I've been using this
one for a few months without any significant problems. However, now
suddenly the Windows stamp editor cannot recognize the Stamp when I
try to run a program. I ohmed out the serial cable, it's still good.
The power LED on the Super Carrier board lights when a battery is
connected to the voltage regulator. I looked at all of the pins with
an o-scope: Vdd and S-out have 5VDC; Vss, Vin, and ATN have 0V; and S-
in has nearly 4V. Most i/o pins have near 0V except 2 and 3 which
have 1.2V. This can't be explained by the last program loaded to the
stamp.
Does anyone have any idea how to fix this? Any help would be greatly
appreciated.
Dan Fox
dfox at stmartin dot edu
stamp.
appreciated.
Dan Fox
I had to change my Com port setting but do not remember which one fixed it.
Also, carefully measure the voltage on the stamp input pin #1. It should be
a negative voltage and will go toward ground when you do a Verify from the
software. Pin 2 should likewise take a dip in voltage if the stamp
responses back.
A scope may tell you more.
Good luck, Kirk
From: dan_fox2002 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rGRLlMmLhzW64k2FdlVpolJEBkOzUO7W3tnbxWsOeUPOdjSyJQCOUBpNPy1TcbyY6hqKSeWO5Vu25wA]dan_fox2002@y...[/url
Sent: Saturday, April 13, 2002 8:26 PM
Subject: [noparse][[/noparse]basicstamps] Unresponsive BS2SX
stamp.
appreciated.
Dan Fox
support, they suggested testing the oscillator, apparently this usually quits
working when the BS2 does. I looked at it, it wasn't doing anything so I ordered
another one and everything works now.
Dan
"WASSON, KIRK D" <kwasson@e...> wrote: Dan, I just had this problem
after loading the new Editor software.
responses back.
Good luck, Kirk
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
I checked the regulated 5vdc on pin 22 and it is good.
Anyone have good troubleshooting tips or is someone repairing them?
Kirk
From: dan fox [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=z0YjXDsZzJOlWvHEBJH9ud34wPm7iGbVnnFSTjRc1ke0rWBj_HFNmF1sCihM09BQHzSBSt_0NZrv8yV2w4n_2A]dan_fox2002@y...[/url
Sent: Thursday, April 18, 2002 12:40 PM
Subject: RE: [noparse][[/noparse]basicstamps] Unresponsive BS2SX
Thanks for the suggestions, but unfortunately the chip is gone. I called
tech support, they suggested testing the oscillator, apparently this usually
quits working when the BS2 does. I looked at it, it wasn't doing anything so
I ordered another one and everything works now.
Dan
responses back.
Good luck, Kirk
Do You Yahoo!?
that the Stamp was still running the program that was last
downloaded to it. (even sending back debug data) but it would not
accept programming commands. Even the identify command would not
recognize the unit. Put a new BS2 in the same slot, with the same
hardware, same cable, same pc, and it worked fine. Strange..
Jody
--- In basicstamps@y..., "WASSON, KIRK D" <kwasson@e...> wrote:
> I also have a BS2 that quit working and another one fixed the
problem.
> Kirk
> From: dan fox [noparse][[/noparse]mailto:dan_fox2002@y...]
> To: basicstamps@y...
called
this usually
anything so
> Dan
problem
fixed it.
should be
from the
> responses back.
> Good luck, Kirk
> Do You Yahoo!?
> basicstamps-unsubscribe@y...
Subject and
me a replacement processor.
> One of the BS2's that we had did the same thing. Strange this was
Mine (BS2) also have the same problem. After loading some program, and
running it works fine. But after disconnecting the power from the BS2 and
after few days when I connected the stamps it already running the previously
loaded program. Then I couldn't load any programs with stamp2.exe, but I
ultimately got around the problem with Basic Stamp Editor V1.3, with that
you can load new programs.
Dn.
Sent: Sunday, April 21, 2002 6:59 AM
Subject: [noparse][[/noparse]basicstamps] Re: Unresponsive BS2SX
> Jody
> problem.
> > Kirk
> called
> this usually
> anything so
> > Dan
> problem
> fixed it.
> should be
> from the
> > responses back.
> > Good luck, Kirk
> > Do You Yahoo!?
> Subject and
