Radio dimmers
I am new to the whole basic stamp thing and have some questions. Here
goes.
I would like to build a multi channel(4) wireless dimmer unit that
will operate on 12v dc. The transmitter will be driven by a lighting
board.
Questions-Will the stamp have a fast enough response time to be used
like a wired dimmer(aka real time)?
-Is there a transmiter/reciever that works best with a basic stamp?
-There will need to be a converter of some sort between the lighting
board and the transmitter? The board uses DMX but I could get an
analoge(0-10v) converter.
-Does anyone know of a transistor circuit that can be used as a
dimmer in conjunction with a stamp?
I know this is alot to ask but I'd rather not re-invent the wheel if
someone already has done something similar.
From everything I have discovered so far, the basic stamp seems to be
extremly versitile and excactly what I need.
Ian Phillips
Shaw Festival
goes.
board.
Ian Phillips
Shaw Festival
section. They have transmitters, receivers, and transcievers for cheap and
they will do the trick nicely. I am using the transciever for a two data
link to a R/C controlled submarine and they work great.. With these RF
devices you can have one transmitter and as many receivers as you want and
simply make each one have a unique address and then it will only respond to
commands sent to it's address..
Mike B.
Sent: Saturday, April 13, 2002 12:53 PM
Subject: [noparse][[/noparse]basicstamps] Radio dimmers
> goes.
> board.
> Ian Phillips
> Shaw Festival
wouldn't be as fun as doing it yourself! I know there are some DMX dongles
that connect to a serial port for either transmitting or receiving. They
come with software to work with the Palm Pilot. Perhaps it would be easy to
interface with them.
E-mail me privately and I can look up the info for you (I don't read the
Stamp maillist very much anymore)
joe@p...
Joe Dunfee joe@d...
Strasburg, Pennsylvania, U.S.A.
From: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TBw_Ye3hcnU_F5t5jaoB5q50rnYlM8AmInOAamFo3rYmCKCSQuei-GjtcBm2vz2mL0WsbeAZinJRVlo5]chris@m...[/url
Sent: Saturday, April 13, 2002 8:35 PM
To: 'basicstamps@yahoogroups.com'
Subject: RE: [noparse][[/noparse]basicstamps] Radio dimmers
These can be made to work very simply with Stamps if your application does
not have to be very precise, such as a typical hobby app. In some other
applications this may be OK.
Most RF com specs require some kind of data validation and re-transmission,
as well as determination on what to do when bad data is received. This
generally calls for a closed loop, or at least 1/2 duplex operation. The
Stamps can do this, but at their baud rates it can be difficult to implement
all that is needed to satisfy a real specification at any speed. Interfacing
to a PC will make your process wait an unknown amount of time for the PC -
which makes your handshaking require a bit more effort, and slows the
process down considerably more.
My point is that for a commercial application, don't expect to work out all
the details overnight.
On the other hand, if you only need to repeatedly send serial data from a
stamp via an RF link continuously, hoping that it will be received
correctly, this truly is fairly simple and can be done without much effort
if an off-the-shelf TX/RX pair is used.
Chris
> Piece of cake. Go to the STamps web site and look at the RF products
> for cheap and
> for a two data
> With these RF
> you want and
> only respond to
> Mike B.
> From: "iphillipsca" <iphillips@s...>
> questions. Here
> > goes.
> > board.
> seems to be
> > Ian Phillips
> > Shaw Festival
> the Subject and
