simple solution needed
hi guys,
has anyone written a simple program with a BS2 that will sequence a relay
closure every time a switch is pushed? simple code I guess, I.e., "button"
"count", etc. Need 12 relays to close one at a time in sequence each time a
push button is pressed and then go back to relay one again. any help to save
some time is appreciated
thanks
mike m
thanks
mike m
'{$STAMP BS2}
OutNo Var Byte
loop:
for outno = 1 to 12
inputwait:
if in1 = 0 then inputwait
pause 1
PULSOUT OutNo,65100 'Turn on output for a while
next
GOTO Loop
Leroy
mocenter wrote:
> hi guys,
> thanks
> mike m
mike m
To: <basicstamps@yahoogroups.com>; <mocenter@e...>
Sent: Saturday, April 13, 2002 2:07 PM
Subject: Re: [noparse][[/noparse]basicstamps] simple solution needed
> Would this work for you:
> '{$STAMP BS2}
> OutNo Var Byte
> loop:
> for outno = 1 to 12
> inputwait:
> pause 1
> next
> GOTO Loop
> Leroy
> mocenter wrote:
> > hi guys,
relay closure every time a switch is pushed? simple code I guess, I.e.,
"button" "count", etc. Need 12 relays to close one at a time in sequence
each time a push button is pressed and then go back to relay one again. any
help to save some time is appreciated
> > thanks
> > mike m
