Opto22 G4 8-channel I/O Module Rack
Hi, Andrew. I'm planning on using the Stamp Controller Interface
Board and the Opto-22 I/O module rack in my project, (which involves
turning on& off AC loads.) The CI board has some ULN2003 chips
(darlington drivers), according to Jon W. and John B.. Here's a link
to the TI datasheet, with application examples:
http://www-s.ti.com/sc/ds/uln2003a.pdf
The stamp pins can connect directly to the input pins of the 2003.
The (+) logic pin of the output module is connected to +5V.
The (-) logic pin of the output module is connected to the output pin
of the 2003. Don't forget ground. When the stamp pin goes high, the
output module turns on.
I haven't gotten the boards yet (waiting for purchase order
approval), but when I do, I can tell you more about how the resistors
and 2003 are wired to the stamp pins. Come to think of it, a
schematic of this CI board would be very helpful.
The Opto 22 web site has lots of information:
http://www.opto22.com/
The board that Parallax sells is #G4PB8.
-Marie
--- In basicstamps@y..., "manwithapipe" <manwithapipe@y...> wrote:
> I am beginning a project pertaining to automated watering routines
> for plants. I have been attempting to utilize water pumps and
other
> items, although I am baffled as to how to use the module rack. I
> cannot seem to find one bit of documentation or sample code showing
> the relationship between the StampIC (inteface board) and the
Opto22
> rack. Both have independent descriptions, but Parallax fails to
show
> how one should go about programming the darn BS2 to use it with the
> rack. Any source or suggestions? Thanks!
> Andrew
-Marie
other
Opto22
show
> Andrew
-Marie
other
Opto22
show
> Andrew
http://www.parallaxinc.com/html_files/products/BS_Boards/stamp-ci_brief.asp for
the Stamp Controller Interface Board. There's a code sample at the end of the
AppNote on how to read in from a Digital Input module and to set a Digital
Output module.Kevin K AsatoKC6POB--- manwithapipe wrote:> I am beginning a
project pertaining to automated> watering routines > for plants. I have been
attempting to utilize water> pumps and other > items, although I am baffled as
to how to use the> module rack. I > cannot seem to find one bit of
documentation or> sample code showing > the relationship between the StampIC
(inteface> board) and the Opto22 > rack. Both have independent descriptions,
but> Parallax fails to show > how one should go about programming the darn BS2
to> use it with the > rack. Any source or suggestions? Thanks!> > Andrew> > >
To UNSUBSCRIBE, just send mail to:> basicstamps-unsubscribe@yahoogroups.com>
from the same email address that you subscribed. > Text in the Subject and Body
of the message will be> ignored.> > > Your use of Yahoo! Groups is subject to>
http://docs.yahoo.com/info/terms/ > >
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
