Pbasic question
The line follower example posted at the parallax site uses the
following code to read the IR sensors:
Read_Line_Follower:
lfBits = 0 ' clear last reading
FOR ledPos = 2 TO 6
OutL.LowBit(ledPos) = LEDon ' turn the LED on
PAUSE 1 ' allow sensor to read
lfBits.LowBit(ledPos) = In9 ^ LFmode ' record the sensor
reading
OutL = OutL | %01111100 ' turn LEDs off
NEXT
lfBits = lfBits >> 2 ' shift bits to zero
index
RETURN
I've read through the manual, but haven't figured out what's the
reason/advantage of using:
instead of
lfBits.Bit(ledPos) ????
lfbits is a byte, not an array.
Any ideas?
Read_Line_Follower:
FOR ledPos = 2 TO 6
reading
NEXT
index
RETURN
instead of
Any ideas?
as such. For Nibs, Bytes and Words, the LowBit modifier allows access to
individual bits and works well for the Line Follower code.
There is no Bit modifier for variables, so the syntax you suggested would not
compile.
-- Jon Williams
In a message dated 4/12/02 2:11:11 PM Central Daylight Time,
Paul.h.garcia@B... writes:
> instead of
> Any ideas?
The ledPos is an array, and the information you are looking for is in
Chapter 4 of the Basic Stamp Manual,
sections Defining Arrays, and Aliases and Modifiers pages 51 thru 55 in the
bound manual, and pages 53 thru 57 in
the PDF manual.
Have Some Fun !!
Dale Fleischmann
> Read_Line_Follower:
> FOR ledPos = 2 TO 6
> reading
> NEXT
> index
> RETURN
> instead of
> Any ideas?
