Watching video on Laptops
Archiver
This is not directly Stamps, but...
In my project I have to watch a for an optical event with video camera (RCA
video output) on my laptop screen. If that would have been a "normal"
computer - there would be no problem putting in a video or TV card with a
RCA (Video-in) input and I would have been done.
I found a X10 Video-to-USB cable that allows to do that, and some older,
used PCMCIA cards that suppose to do the same. Are there any new Video-in
PCMCIA cards?
X10 cable is about $70 and Belkin makes a similar one. There is also TV
cards with USB connection.
Am I missing something ar these are my only choices? Anyone knows about any
new Video-in PCMCIA solutions? I am using older touch-screen laptops that
has no USB!
Thanks for your help,
Alex Chaihorsky
PCMCIA cards?
has no USB!
Alex Chaihorsky
http://www.irez.com
-Chilton
> any
> that
> has no USB!
camera. Almost all the video capture solutions today are PCI card, USB, or
firewire.. Not too many others out there.
Plus if you get the firewire card you have a bunch of devices you can use.
I guess you could also try to find a USB PCMCIA card, that would allow you
to use the USB cameras/video capture solutions.
-Rob
Sent: Tuesday, April 09, 2002 5:16 AM
Subject: [noparse][[/noparse]basicstamps] Watching video on Laptops
(RCA
> PCMCIA cards?
any
> has no USB!
> Alex Chaihorsky
Try this http://www.margi.com/products/default.html . I bought the "TV
to GO", NTSC & PAL supported. I can now use any Video input in to my
ageing Tosh Satellite Pro (computer must have a ZV supported PCMCIA
port).
Rob
---Original Message
From: Alex Chaihorsky [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=sORBnqymY6K-HHBtwO-MXHroDSpTHb75dmv4qUN6BEHXyeS-zp3Pfdup8PlBiJpLZzYgruNOGTR9ZIK90_uIL26yG41Wdw]alex_chaihorsky@h...[/url
Sent: 09 April 2002 10:16
(RCA
a
Video-in
PCMCIA cards?
any
that
has no USB!
Alex Chaihorsky
PCMCIA/PCCard interfaces. I have an older Toshiba
Tecra running Windows 98 which has 16-bit PCMCIA
slots. These will not support some of the newer cards
(ie., USB PCCard is not supported as it is a 32-bit
interface). You may find this true with a video
capture or TV PCCard.
Kevin K Asato
KC6POB
--- Alex Chaihorsky <alex_chaihorsky@h...>
> PCMCIA cards?
> has no USB!
> Alex Chaihorsky
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
http://taxes.yahoo.com/
The "new" cards are Cardbus -- fortunately they have little titties on the
edge of the card that prevent you from plugging them into a slot designed
for the older PCMCIA cards. You can run an old card in a new machine, but
not vice-versa.
> Be careful when using older laptops and newer
this interface card went right in with normal effort.
There was a bit of trouble getting this card
recognized by the OS and erratic driver operation.
Only after experiencing these problems was I able to
find the notation in the manual describing the 16-bit
nature of the port.
--- Rodent <daweasel@s...> wrote:
> Charles E. Fromage says:
> not vice-versa.
> cards
> 32-bit
> ignored.
Do You Yahoo!?
