MIDI out can''t coexist with other form of outputs
Name unknown:
I don't know why you leave open the pin 15 with the
$8000 in the serout command. I think you need to drive with the two state 1
and 0
Serout 15,12,[noparse][[/noparse]xx,yy,zz]
My two cents
Roberto
Sent: Saturday, April 06, 2002 5:55 PM
Subject: [noparse][[/noparse]basicstamps] MIDI out can't coexist with other form of outputs
> Ok I have a school project which is using 8 pins to trigger 8 24 volt
> relays (with the use of transistors) and it also sends out 10
> different midi velocities formsomething else. The problem that I'm
> having is that neither of these can coexist for some reason. When
> only the midi is running everything works fine and when only the 8
> outputs are running every relay switches fine. As soon as everything
> is plugged in, the midi stops working after 5-10 seconds. I just
> wanted to know f someone can look at the code and tell me if there's
> anything wrong or not. Thanks!
> Here's the sample:
> note: I'm simply reading to values that are coming in on pins 1 and 2
> and based on the values toggling certain pins and sending certain
> midi velocities.
> MAINLOOP:
> control = sensorX - sensor Y (the sensors work fine)
> IF control < 2000 THEN goto setup1
> IF control.....
> setup1:
> HIGH 1
> HIGH 2
> HIGH 3
> HIGH 4
> LOW 5
> LOW 6
> LOW 7
> LOW 8
> serout 15,$8000+12,0,[noparse][[/noparse]144,0,127]
> serout 15,$8000+12,0,[noparse][[/noparse]144,1,127]
> serout 15,$8000+12,0,[noparse][[/noparse]144,2,127]
> serout 15,$8000+12,0,[noparse][[/noparse]144,3,127]
> serout 15,$8000+12,0,[noparse][[/noparse]144,4,127]
> serout 15,$8000+12,0,[noparse][[/noparse]144,5,0]
> serout 15,$8000+12,0,[noparse][[/noparse]144,6,0]
> serout 15,$8000+12,0,[noparse][[/noparse]144,7,0]
> serout 15,$8000+12,0,[noparse][[/noparse]144,8,0]
> serout 15,$8000+12,0,[noparse][[/noparse]144,9,0]
> Goto MAINLOOP
> setup2:
and 0
My two cents
Roberto
> Here's the sample:
> midi velocities.
> MAINLOOP:
> IF control.....
> setup1:
> HIGH 1
> HIGH 2
> HIGH 3
> HIGH 4
> LOW 5
> LOW 6
> LOW 7
> LOW 8
> Goto MAINLOOP
> setup2:
