RC time — Parallax Forums
RC time
edited 2002-12-08 06:47 in General Discussion
Does any one the practical limits of R & C on the RC time command? In
other words would it be possible to accurately measure capacitance of
around 10 pf to 75 pf?
thanks for your help.
Leroy Hall
    edited 2002-04-06 18:35
    Hi Leroy,
    The RCtime command is at best good for about 10 bits of accuracy.
    That is when you can achieve an RC time constant of around 1000
    counts (2000 microseconds). With 10pf, the R required would be ~200
    megaohms, which is not practical.
    Now, say you have a 1 megaohm resistor, the RC time constant will be
    roughly 10 microseconds, which is an RCTIME count of only 5. So that
    is not what you would call, "accurate". Even with 10 megs R, the
    count is only ~50.
    You also have to consider that the input pin of the PIC or SX chip
    itself has a capacitance of ~5pf, plus whatever leadframe and wiring
    capacitance there is in your layout. (Warning to those using white
    block breadboards--the capacitance between nodes is a whopping
    ~300pf).
    For those small capacitances, you are probably better off using an
    external IC, even a '555, to generate a frequency you can measure
    with the COUNT or PULSIN command.
    -- regards,
    Tracy Allen
    mailto:tracy@e...
    http://www.emesystems.com
    >Leroy Hall
    edited 2002-12-08 00:47
    Hi everyone,
    I am trying to use the RC time with a BS2 and I can't get it to
    work. If you put a resistor and cap in parallel, isn't that an RC
    time constant? I don't know if my code is wrong or what the problem
    is. Can anyone point me in the right direction or help me with some
    code.
    Chris
    edited 2002-12-08 01:02
    Both the manual and the compiler help file show the proper connections and
    code.
    -- Jon Williams
    -- Parallax
    In a message dated 12/7/02 6:50:25 PM Central Standard Time,
    CHRIS@R... writes:
    > Hi everyone,
    > code.
    > Thanks,
    > Chris
    edited 2002-12-08 01:08
    What is the compiler?
    connections and
    > code.
    > -- Jon Williams
    > -- Parallax
    > CHRIS@R... writes:
    > > Hi everyone,
    RC
    problem
    some
    > > code.
    > > Thanks,
    > > Chris
    edited 2002-12-08 02:51
    The editor/compiler is what you use to program BASIC Stamps.
    -- Jon Williams
    -- Parallax
    In a message dated 12/7/02 7:09:16 PM Central Standard Time,
    CHRIS@R... writes:
    edited 2002-12-08 03:25
    John,
    I did not ask that question but I was wandering if you could help me.
    I have very little programming experience but I have very technical
    background in electronics.
    I am building a project and I need help on some coding.
    I am building 3 seperate control boards with a n/o momentary switch and a
    led circuit to flash on each board.
    I want to push all 3 switches at once, and let my stamp determine which
    board pushed first and light up only that boards led circuit to flash and
    then push a reset button to start it again.
    An a example would be like a 3 contestant game show. The first one to push
    their button the fastest, their podium light will flash.
    I have most of the circuits designed just don't know how to start my code.
    Todd Kaiser
    Sent: Saturday, December 07, 2002 9:51 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: RC TIME
    > -- Jon Williams
    > -- Parallax
    > CHRIS@R... writes:
    edited 2002-12-08 03:59
    I hate posting simplistic code to the list because I don't want anyone to
    think I'm encouraging bad ("quick and dirty") coding habits. Please download
    StampWorks from our web site -- it will help you to understand this little
    program.
    sw1 VAR In0
    sw2 VAR In1
    sw3 VAR In2
    rst VAR In3
    Leds VAR OutB
    Led1 VAR Out4
    Led2 VAR Out5
    Led3 VAR Out6
    Setup:
    Leds = %0000
    DirB= %0111
    Check_1:
    IF (sw1 = 1) THEN Check_2 ' not pressed
    Led1 = 1 ' turn LED on
    GOTO Wait_For_Reset
    Check_2:
    IF (sw2 = 1) THEN Check_3
    Led2 = 1
    GOTO Wait_For_Reset
    Check_3:
    IF (sw3 = 1) THEN Check_1
    Led3 = 1
    GOTO Wait_For_Reset
    Wait_For_Reset:
    IF (rst = 1) THEN Wait_For_Reset
    Leds = %0000
    GOTO Check_1
    This program assumes inputs are active low -- that is, they are normally
    pulled up to 5 volts [noparse][[/noparse]through 10K] until a N.O. button them to ground. The
    LEDs are active high. Connect the LED outputs to LEDs through suitable
    current limiting resistors [noparse][[/noparse]470 ohms].
    Consult the manual and the StampWorks book to fully understand the program.
    Basically, when a button is pressed, the associated LED is lit and will stay
    lit until you press the reset button. This is a very simplistic approach.
    You could also grab all three inputs at once, then scan the captured inputs.
    Try this version first; then upgrade it as you improve your programming
    skills.
    -- Jon Williams
    -- Parallax
    In a message dated 12/7/02 9:26:57 PM Central Standard Time,
    tkaiser@w... writes:
    > John,
    > Thanks,
    edited 2002-12-08 05:16
    In a message dated 12/7/2002 8:01:00 PM Pacific Standard Time, jonwms@a...
    writes:
    Jon Williams is the "guru," however, I strongly suggest you use his second
    suggestion to grab all inputs at once. The reason is as follows, if you want
    to be really "precise" with your idea.....
    What can happen is this: The code Jon suggested checks each switch one at a
    time, the first sw, the second sw, then the third sw and then repeats the
    checks. It takes a some time (not much, maybe 500 us) to check the status of
    each sw before it checks the next sw.
    In theory, the person who pushes button one can get screwed if .....the stamp
    checks pin one, and during the time the stamp is checking pin 2, user 1 and 3
    both press their button, but user one presses before user three. Since the
    stamp just finished checking user 1 and is about to check user 3, the stamp
    will indicate user 3 was first when in reality user one was first.
    The chances of this occuring are remote, but if you want to be precise, this
    method is just as easy to code, and more exact to meet your requirement.
    My syntax below might be wrong (stamp book is at work and I don't use it much
    more in favor of the SXAC because it is "lighting fast" compared to the stamp
    and $50 cheaper. But at the same time, the Stamp is MUCH EASIER to write code
    for)
    Anyway, you can read the status of 4 input pins at once as follows (again
    syntax might be wrong)
    buttons var nib
    buttons = INA 'which will grab the status of pin 0, pin 1, pin 2 and pin
    3.
    'Tie the unwanted input pin low. Once you grab the nibble (4 bit value INA)
    buttons = INA AND %0111 'this assumes that bit 4 (pin 3 is the unwanted pin)
    Then check the which bit is low, p0, p1 or p2 using the code Jon wrote
    Again, if you want to be more "precise", use the second suggestion from Jon,
    that is read all pins at once for the reason I described. I actually made
    this circuit once (Like the Jeapordy game....who pressed first) just using
    four IC's, which is a much cheaper solution than the stamp with one draw
    back, that is the time to wire it.
    That is what is so beautiful about the Basic Stamp, its ease of use. I used
    to build all kinds of "custom" hobby circuits from discrete IC's. The Basic
    Stamp can save lots of time for some extra $$. It's all a trade off......
    if you want details on the discrete IC circuit I would be glad to share it
    with you.
    Regards
    > stay
    > inputs.
    > skills.
    > -- Jon Williams
    > -- Parallax
    edited 2002-12-08 05:32
    I've been following along with these posts and I am interested in this last
    one especially. I have been throwing ideas around as to how I can make one
    of these, and I was wondering if I could see your discrete IC circuit. Thank
    you very much.
    Matthew Mangione
    From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IRx3slzIy6ogkKZ5tkjrmO5WsOewH4l2zv4Ly5yU_vl5Z5s5yk7eECx1AuZc1z_xlJNqk2cB9FowZ0g]smartdim@a...[/url
    Sent: Sunday, December 08, 2002 12:17 AM
    To: basicstamps@yahoogroups.com; JonWms@a...
    jonwms@a...
    writes:
    stamp
    3
    much
    stamp
    code
    for)
    buttons var nib
    3.
    pin)
    with you.
    Regards
    The
    program.
    > stay
    > inputs.
    > skills.
    > -- Jon Williams
    > -- Parallax
    edited 2002-12-08 06:46
    Here you go...if this is not understandable, leave me a FAX number and I can
    fax a schematic Monday.....
    Sorry, 5 IC's.....not 4, still less than $10.00
    The heart of the circuit it a HEX, Quad or Octal D Flip Flop (ex 74HC174, or
    74HC175 or 74HC273) depending on how many switches you want to monitor.
    Lets say 4 inputs (switches) for example
    Connected to the clock input of the D FF is a logic level pulse from the
    output of a 74HC20 4 input nand gate. The input to two of the pins of the
    74HC20 come from a 555 timer that is running at 1k hertz or much higher. If
    you run the 555 (or other device) at 1k hz the switch status is checked every
    millisecond. If you run the 555 at 10k hz the switch status is checked every
    100 uS. You can even go up to 50kHz or higher.
    Anyway, a logic level frequency goes to the clock input of the D Flip Flop,
    but through the nand gate. You will see why later. (I actually ran the output
    of the 555 to the base of a 2n3904 transistor through 63k ohms. Emitter of
    the 3904 to ground and the colletor to 5 volts through 10k ohms and the
    collector to the input of the nand gate. This will ensure the clock input of
    the FF goes all the way to 5 volts and darn close to 0 volts as the 555
    output typically falls short of making good logic level voltages)
    The HC174 has 6 D inputs...
    FOUR INPUTS of the D Flip flop will have the following:
    (The other 2 inputs tie to ground)
    10K ohms to +5 volts and to one side of a normally open switch.
    The other end of the N.O. switch to ground.
    The four Q outputs of the D FF that correspond to the four D inputs used (D1
    - Q1, D2, Q2 etc) will have the following (the two unused ones leave open, no
    connection):
    The Q outputs will go to TWO places:
    1) the input terminal of a 4 input nand gate (like a 74HC20)
    2) the input terminal of a buffer (like a 74HC125)
    All "C" terminals of theHC125 to ground
    Each output of the HC125 to an LED through 470 ohms to +5 volts
    The output of the nand gate goes to the input of an XOR gate (like a 7486)
    The other input of the XOR gate goes to one terminal of a normally open
    switch, the other end of the switch to ground.
    The output of the XOR gate goes to the other two pins of the remaining nand
    gate that has the output of the 555 timer.(the 74HC20 has two 4 input nand
    gates)
    The other two pins of the HC20 get connected to the collector of the 2n3904
    as previously described.
    So.....this is how it works (I will probably need to fax a schematic!!)
    1) With no switch pressed the input to each D FF (ignore the two FF D inputs
    grounded) if HIGH
    2) Each output of the D FF is HIGH
    3) Each output of the HC125 output is HIGH turning off each LED
    4) The output of the 4 input nand gate (the one connected the Q outputs of
    the FF) LOW
    5) The XOR gate has one input HIGH via the reset switch not pressed and one
    input LOW from the output described in 4 above
    6) The XOR output is HIGH and connected to the "other" 4 input nand gate,
    this allows the 1kHz 555 signal to get through to the D FF.
    7) Every clock edge of to the D FF the input switches are check.
    NOW, WHEN SOMEBODY PRESSES A SWITCH THIS IS WHAT HAPPENS
    1) The D input of the HC174 is LOW, making the Q output LOW.
    2) The input of the HC20 buffer is LOW making the output LOW turning of the
    LED
    3) At the instant the output of the HC174 goes LOW the input of the 4 input
    nand gate (the one connected to the Q outputs of the D FF) goes HIGH
    4) Step 3 makes both inuts to the XOR gate high which makes it output LOW
    5) Step 4 makes two of the inputs of the "2nd" nand gate LOW effective
    shutting off the clock input to the D FF.
    At this point the circuit is "latched" with whatever switch went low.
    To reset the circuit when you push the rest switch the clock pulses then go
    to the HC174 and as long as none of the user switches are pushed, all LEDs
    are off and again the circuit is checking the status of switches every
    1/clock frequency
    WHEW!!!! Whats your fax number. About 1/2 way through I realized this is
    not easy to explain how to wire it. As they say a picture (schematic) is
    worth a thousand words. How true in this case!!
    Again, if will fax a schematic if you want and can provide more explanation
    is needed....
    Good luck!
    Hi Todd,
    You might be interested in the program "state machine: game show" posted at
    http://www.emesystems.com/BS2fsm.htm
    This is a tight 4-line program that shows the first, second and third
    place finishers by the rate of flashing of the lights. The program
    came from a question on this list a while back.
    -- Tracy
    >John,
    >Thanks,
    >Todd Kaiser
    >From: <jonwms@a...>
    > > -- Jon Williams
    > > -- Parallax
    > > CHRIS@R... writes:
    >Subject and Body of the message will be ignored.
