Switch debounce
Could someone please give me a suggestion why the following program
doesn't work..
I am trying to write a program to debounce a switch. I thought I would
like have the stamp check the switch & if it found it closed then check
it 50 more times and if it was still closed after that time then state
it is closed and vice versa for it being open. Here's my program. Yep,
you guessed right, it doesn't work.
Thanks for your help..
Leroy
'{$STAMP BS2}
x var byte
x0 var bit
x1 var bit
x2 var bit
pin1 con 1
loop:
if pin1 = 1 then one
if pin1 = 0 then zero
debug cr
DEBUG "the pin status is: ", bin1 x1
goto loop
zero:
x1=1
for x = 1 to 50
if pin1 = 1 then loop
x1=0
next
return
one:
x0=0
for x = 1 to 50
if pin1 = 0 then loop
x1=1
next
return
doesn't work..
Leroy
'{$STAMP BS2}
x var byte
x0 var bit
x1 var bit
x2 var bit
pin1 con 1
loop:
debug cr
goto loop
zero:
x1=1
for x = 1 to 50
x1=0
next
return
one:
x0=0
for x = 1 to 50
x1=1
next
return
Two thoughts without knowing what your failure is.
1) In your debug statement you print x1 but in your one: routine you
set both x0 and x1. What is x0 used for?
2) I would be worried about the number of times that you break out
of a subroutine without a return when you detect a changed value at
the pin. (Others more knowledgeable can tell you if this is a real
problem.) You might try the following:
zero:
x1=1
for x = 1 to 50
if pin1 = 1 then zero_one
next
x1=0
zero_one:
return
one:
x1=0
for x = 1 to 50
if pin1 = 0 then one_zero
next
x1=1
one_zero:
return
( * * * Untested code, but compiles OK. * * * )
Phil
> doesn't work..
would
check
state
Yep,
> Leroy
> '{$STAMP BS2}
> x var byte
> x0 var bit
> x1 var bit
> x2 var bit
> pin1 con 1
> loop:
> debug cr
> goto loop
> zero:
> x1=1
> for x = 1 to 50
> x1=0
> next
> return
> one:
> x0=0
> for x = 1 to 50
> x1=1
> next
> return
You have pin1 defined as a constant=1, so it is always going to be
one. I think what you want is an alias variable:
pin1 var in1 ' another name for the input pin 1
Also, "zero:" and "one:" are subroutines with returns at the end,
but the lines that go there ("if pin1=1 then one") are plain branch
commands, not subroutine calls. You may find the actual BRANCH
command useful:
BRANCH in1,[noparse][[/noparse]zero,one]
My bias is to implement the debounce function with math only and no
branching. Here is one way:
x var byte
loop:
x=x max 49 min 1 + (in1<<1-1)
x1 = x1 | (x min 49 - 49) & (x max 1) max 1
debug "count=",dec x,tab, "the pin status=",bin x1,cr
goto loop
It is kind of funny math, but it makes sense if you think it through.
The first line increments the count x up as high as 50 or decrements
back to zero 0, depending on the state of the input. Think about the
term in parentheses:
(0<<1-1) if in1=0, then () equals -1 so x decrements
(1<<1-1) if in1=1, then () equals +1 so x increments
The "<<1" means shift left one, which is equivalent to mulitply by two.
The next line starting with "x1=" works on the debounced status bit
x1. x1 appears on the right hand side of the expression, so x1 holds
its value unless something happens in the terms in parentheses. The
first term in parentheses, (x min 49 - 49), is zero until x reaches
50, at which time it flips the status output to x1=1. The "|" is
logical OR. The second term in parentheses (x max 1) is one unless
x=0, so when x gets back to zero, the output status flips back to
x1=0. The "&" is the logical AND operator.
-- regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
>doesn't work..
>Leroy
>'{$STAMP BS2}
>x var byte
>x0 var bit
>x1 var bit
>x2 var bit
>pin1 con 1
>loop:
>debug cr
>goto loop
>zero:
>x1=1
>for x = 1 to 50
>x1=0
>next
>return
>one:
>x0=0
>for x = 1 to 50
>x1=1
>next
>return
It is setup for Debounce Button Input
Ken Kaufman
Senior Engineer
Vertex/RSI
Phone: 903-295-1480 Ext 270
Fax: 903-295-1479
E-Mail: ken.kaufman@t...
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1w6cwsZICXAJOIZFZ9GT3aBH02o7C3pFt4zR6v9vJIO8l05CApe5JRWB4hUSIEezkOrkdgSmRPOzPQ0]tracy@e...[/url
Sent: Wednesday, April 03, 2002 3:16 PM
Subject: Re: [noparse][[/noparse]basicstamps] Switch debounce
Hi Leroy,
command useful:
x var byte
loop:
goto loop
-- regards
Tracy Allen
mailto:tracy@e...
>doesn't work..
>Leroy
>'{$STAMP BS2}
>x var byte
>x0 var bit
>x1 var bit
>x2 var bit
>pin1 con 1
>loop:
>debug cr
>goto loop
>zero:
>x1=1
>for x = 1 to 50
>x1=0
>next
>return
>one:
>x0=0
>for x = 1 to 50
>x1=1
>next
>return
I think that this little piece of code will accomplish what you
are looking for.
Larry
P.S. This is "payback" for your help! ;-)
TBit VAR Bit
INX VAR Byte
Loop:
TBit=IN1 XOR 1
FOR INX=1 TO 50
IF IN1=TBit THEN Loop
NEXT
DEBUG DEBUG "the pin status is: ", IN1, CR
Explanation:
Using the XOR operator will set TBit to the opposite of IN1;
i.e.,
IN1=1, TBit=0; IN1=0, TBit=1. If the value of IN1 changes within
the FOR loop we will restart the FOR loop and test for the "new"
IN1
value. We will stay in this looping situation until we see a
constant
value for IN1 for 50 iterations.
> From: Leroy Hall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=M-0TwHr5rpVUaNo7Q0IKvg9kCzxLaNSVUMe4S-ctioL4mXdB1JaCOpldr2bMRKEPr0nEzg]leroy@f...[/url
> Sent: Wednesday, April 03, 2002 11:46 AM
> To: basicstamps@yahoogroups.com; Leroy Hall
> Subject: [noparse][[/noparse]basicstamps] Switch debounce
> following program
> doesn't work..
> thought I would
> closed then check
> time then state
> my program. Yep,
> Leroy
> '{$STAMP BS2}
> x var byte
> x0 var bit
> x1 var bit
> x2 var bit
> pin1 con 1
> loop:
> debug cr
> goto loop
> zero:
> x1=1
> for x = 1 to 50
> x1=0
> next
> return
> one:
> x0=0
> for x = 1 to 50
> x1=1
> next
> return
> in the Subject and Body of the message will be ignored.
> loop:
> debug cr
> goto loop
> zero:
> x1=1
> for x = 1 to 50
> x1=0
> next
> return
> one:
> x0=0
> for x = 1 to 50
> x1=1
> next
> return
