Using the BS2E for the first time.
I am new to using the stamp processors, I have been using the BS2 and
writing code with the 1.091 version software. I just bought a BS2E
and I need to know if It will run the 1.091 software or do I have to
rewrite the code? If so what version do I use? And can you just plug
it in to the same project board socket? Skip
Code-wise, your new BS2e is 100% compatible with the BS2 code you've written.
With the BS2e, you get three new commands: PUT, GET and RUN.
PUT will place a byte into the scratchpad RAM. The scratchpad (64 bytes) is
available to all eight program slots in your BS2e.
GET retrieves a byte from the scratchpad.
RUN will execute another program slot.
Electrically, the BS2e uses a bit more current than the BS2, but you can
safely put it into your existing project board.
-- Jon Williams
-- Parallax
In a message dated 4/3/02 9:13:39 AM Central Standard Time,
skip.webb@h... writes:
Jon, Thanks for the info. I must have a broken devise because when I
try to run or load the code It wont load an error message says check
the power and I verified that power was OK. Skip
-- In basicstamps@y..., jonwms@a... wrote:
> Skip:
you've written.
bytes) is
you can
> -- Jon Williams
> -- Parallax
and
BS2E
to
plug
Did you remember to change the part description in the file to:
'{$STAMP BS2e}
Phil
I
check
> > Skip:
> you've written.
(64
> bytes) is
> you can
> > -- Jon Williams
> > -- Parallax
BS2
> and
> BS2E
have
> to
> plug
Phil, Thanks I will try that, I didn't know you had to do this!! Skip
- In basicstamps@y..., "n6mwc" <phil@p...> wrote:
> Just a thought:
> '{$STAMP BS2e}
> Phil
when
> I
> check
> > > Skip:
> > you've written.
> (64
> > bytes) is
but
> > you can
> > > -- Jon Williams
> > > -- Parallax
> BS2
> > and
> > BS2E
> have
> > to
just
> > plug
The latest version of the stamp software is 1.3. Download from the
http://www.parallaxInc.com. It automatically checks what type of
stamp is connected to your PC.
The version 1.091 IDE does not do that and requires that you do it
manually as n6mwc pointed out.
-- Tracy
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1WW3c2ngUuO7wPcK0CKM3X-ixNKl7kPPWHX0ICAiFxyYoDvNkVTv82f6XaCg2rgVhm7-CU7Rn-bmCPE]tracy@e...[/url
Sent: Wednesday, April 03, 2002 3:31 PM
Subject: Re: [noparse][[/noparse]basicstamps] Using the BS2E for the first time.
-- Tracy
