Need to talk to someone who has implemented phone interface
I asked the newsgroup about this a few weeks ago, and got some
good pointers. I was looking for a phone line interface. I was
pointed to some sites, found a couple of interfaces and have
ATTEMPTED to implement one, but I just CAN'T get it to work (see
attached GIF of circuit). I am using a capacitor,zener pair,
resister network to feed a 2N27 opto-isolator. It isn't working
for me and I would like to know if anyone has an interface that
works. I need to detect RING so that I can switch the phone line
via a Stamp/Relay combo.
Any help???
TIA,
Larry Woods
Any help???
TIA,
Larry Woods
Your gif file must be uploaded to the groups section of yahoo. But from
your description I would suspect your opto couplers are giving you the
problem. If you will send me the gif file, I will look into the matter
further..
HTH
Leroy
Larry Woods wrote:
> Hi,
> Any help???
> TIA,
> Larry Woods
I would be interested in finding more about the circuit. I am
presently working on a home automation project remotely controlled
through the phone line and any information would be helpful. You can
email me at vmansueto@h....
Vince
--- In basicstamps@y..., Leroy Hall <leroy@f...> wrote:
> Dear Larry,
from
the
matter
> further..
> HTH
> Leroy
> Larry Woods wrote:
> > Hi,
> > Any help???
> > TIA,
> > Larry Woods
> > basicstamps-unsubscribe@y...
Subject and Body of the message will be ignored.
I sent the gif circuit file to your other address.
Let me know if it works..
regards,
Leroy
enzom2000 wrote:
> Hi Larry and Leroy,
> Thanks,
> Vince
> > Dear Larry,
> from
> the
> matter
> > further..
> > HTH
> > Leroy
> > Larry Woods wrote:
> > > Hi,
> > > Any help???
> > > TIA,
> > > Larry Woods
I'm working on a CID project, which basically needs to
detect thr RING that you also need to detect. I'm
detecting that ring with the CID chip. It has a pin
which is driven LOW when a RING is deteted. The chip
costs $CAD 3.00, and it requires a small amount of
external circuitry. I think it is the easiest way of
detecting your ring while actually classifing it as a
valid ring.
you can get the chip from Holtek, www.holtek.com. The
chip is part# HT9032C. The C version is 8 DIP but they
also have a D version which is 4 DIP.
cheers
radu
__________________________________________________
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
http://taxes.yahoo.com/
