Hexapod servo stepping question
Hello all:
I have created a hexapod from scratch and am now programming it to
walk. I am using a Basic stamp2 and 2 Scott Edwards SSC's for serial
leg control. I have succeded in programming the hexapod to perform
pushups and a rough walking cycle. My issue is that I would like to
slow the leg movements down, especially the "stride" part of the leg
walk cycle. I stripped my code down to just one leg to try to "step"
the servo's through a walk cycle, however only 1 servo of the leg
seems to step through properly. I put debug commands throughout the
code below to ensure correct values and that the "for/next" loops as
well as the "serout" commands have the correct values...all's well.
What is absolutely stumping me is the fact that the 1st servo
(servoposa(0)- the stride servo) steps slowly as the code dictates,
but the 2nd servo (the lift servo) does not (it quickly goes to a set
position without stepping), even though the codes debug command shows
it stepping through the entire range of values. I have looked and
tried all kinds of things with the code to solve it but to no avail.
I think another pair of eyes on the code below will spot the issue
(s)? FYI, I have swapped connectors on the leg end to ensure proper
functioning of the hardware....all ok. Any and all feedback would be
appreciated!
Here is the code:
'{$STAMP BS2}
x var nib
y var byte
serposa var byte(2)
serposb var byte(2)
stride var byte
liftl var byte
stride = 70
liftl = -20
serposb(0)= 150
serposb(1)= 90
serposa(0) = 150
serposa(1) = 130
gosub serout1
stand: ' stride and lift routine values
serposa(0) = serposb(0) + stride
' debug dec serposa(0)
serposa(1) = serposb(1) + liftl
' debug dec serposa(1)
gosub serout2
end
serout2: ' This will have the legs step through its values so they
move slowly
x=0
for x=0 to 1
' debug dec x
y=serposb(x)
' debug dec y
for y=serposb(x) to serposa(x)
serout 8,$4054,[noparse][[/noparse]255,x,y(x)]
'debug dec y
pause 20
next
pause 1000
next
pause 500
return
serout1:' this will put the legs in a "home position" before the walk
cycle
x=0
for x=0 to 1
serout 8,$4054,[noparse][[/noparse]255,x,serposa(x)]
next
pause 1000
return
appreciated!
Here is the code:
'{$STAMP BS2}
x var nib
y var byte
serposa var byte(2)
serposb var byte(2)
stride var byte
liftl var byte
stride = 70
liftl = -20
serposb(0)= 150
serposb(1)= 90
serposa(0) = 150
serposa(1) = 130
gosub serout1
gosub serout2
end
move slowly
x=0
for x=0 to 1
' debug dec x
y=serposb(x)
' debug dec y
'debug dec y
pause 20
next
pause 1000
next
pause 500
return
cycle
x=0
for x=0 to 1
next
pause 1000
return
product coming out soon that may help. It is a 16 Serial Controller
from a company called Pololu (see www.pololu.com) They offer a more
robost version of Scott Edwards with control for speed. This way you
aren't burdening the stamp with trying to slow down the code
execution. The idea would be to send one command that tells the
servo not just where to go, but also how fast to move!
--- In basicstamps@y..., "kasaneus" <alex.dirks@w...> wrote:
> Hello all:
to
serial
leg
to "step"
as
set
shows
avail.
be
> appreciated!
> Here is the code:
> '{$STAMP BS2}
> x var nib
> y var byte
> serposa var byte(2)
> serposb var byte(2)
> stride var byte
> liftl var byte
> stride = 70
> liftl = -20
> serposb(0)= 150
> serposb(1)= 90
> serposa(0) = 150
> serposa(1) = 130
> gosub serout1
> gosub serout2
> end
> move slowly
> x=0
> for x=0 to 1
> ' debug dec x
> y=serposb(x)
> ' debug dec y
> 'debug dec y
> pause 20
> next
> pause 1000
> next
> pause 500
> return
walk
> cycle
> x=0
> for x=0 to 1
> next
> pause 1000
> return
would love to see some photos of your machine and I could send you some
photos of mine are you interested? Skip Webb
From: sjoblin001 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tCD87xugUlf97hSkfTp48PfVtyzk8GRKtUf7K10Gc1HP-WYmDkNorUu1mFCW_EEnyAiPzGJMHw]sjoblin@m...[/url
Sent: Friday, April 05, 2002 10:20 AM
Subject: [noparse][[/noparse]basicstamps] Re: Hexapod servo stepping question
This doesn't help with your code problem, but I do know of a new
> Hello all:
to
serial
leg
to "step"
as
set
shows
avail.
be
> appreciated!
> Here is the code:
> '{$STAMP BS2}
> x var nib
> y var byte
> serposa var byte(2)
> serposb var byte(2)
> stride var byte
> liftl var byte
> stride = 70
> liftl = -20
> serposb(0)= 150
> serposb(1)= 90
> serposa(0) = 150
> serposa(1) = 130
> gosub serout1
> gosub serout2
> end
> move slowly
> x=0
> for x=0 to 1
> ' debug dec x
> y=serposb(x)
> ' debug dec y
> 'debug dec y
> pause 20
> next
> pause 1000
> next
> pause 500
> return
walk
> cycle
> x=0
> for x=0 to 1
> next
> pause 1000
> return
started construction yet, so I can't send you pictures for quite a
long time. have you seen the MHEX Robot Walker or Frank Scott's
Hexapod Robots? These are two pretty good sites. Send any pictures
to sjoblin@m.... I have not yet settled on a mechanical design
yet. I would be most interested to know of your experiences. What
materials did you use, how many degrees of freedom does each leg
have, what routines are you using to turn the hexapod, etc.
Steve
--- In basicstamps@y..., "Webb, Skip (FL51)" <skip.webb@h...> wrote:
> I just created a hexapod from scratch and am now programming it
too!! I
some
> From: sjoblin001 [noparse][[/noparse]mailto:sjoblin@m...]
> To: basicstamps@y...
Controller
more
you
> > Hello all:
> to
> serial
perform
to
> leg
> to "step"
the
> as
well.
dictates,
> set
> shows
> avail.
proper
> be
> > appreciated!
> > Here is the code:
> > '{$STAMP BS2}
> > x var nib
> > y var byte
> > serposa var byte(2)
> > serposb var byte(2)
> > stride var byte
> > liftl var byte
> > stride = 70
> > liftl = -20
> > serposb(0)= 150
> > serposb(1)= 90
> > serposa(0) = 150
> > serposa(1) = 130
> > gosub serout1
> > gosub serout2
> > end
they
> > move slowly
> > x=0
> > for x=0 to 1
> > ' debug dec x
> > y=serposb(x)
> > ' debug dec y
> > 'debug dec y
> > pause 20
> > next
> > pause 1000
> > next
> > pause 500
> > return
> walk
> > cycle
> > x=0
> > for x=0 to 1
> > next
> > pause 1000
> > return
> basicstamps-unsubscribe@y...
Subject and
