MAX7219 help
I am using the Max7219 for driving LED 7-seg displays quite
successfuly. I basically used (with very little modification) the
AppNote from Parallax.
However, my current application require using the chip to turn on 64
LED's in rapid sequence from LED 0 (the first) to LED 64. The
Max7219 data sheet is somewhat criptic and I dont' really understand
how to use the chip in non-BCD mode.
Can anyone suggest how I can code the BS2 to do this?
many thanks
Al
many thanks
Al
LED Matrix with a Maxim 7219 LED display driver. All the wiring seems to be
correct, but, I'm getting interference with the some of the LED on the
Matrix (ie Columns 1 & 4 are always on). Below is the section of code that
"drives" the Matrix. I attempted to create a couple of different test
behaviors, I created a character that turns all the LEDs on, to which the
LED Matrix only turns on rows 1 & 4, and columns 2, 3 & 5. The demo in the
article displays the letters B, S, and 2, you can see the letters appear
through the additional LEDs. Any ideas? I'm using a BOE rev d, with a BS2.
All help is appreciated.
MG
--- Code Segment Follows ---
FOR col = 1 TO 5 ' character is 5 columns wide
READ (eeAddr1 + col - 1),d7219 ' read column data from EEPROM
SHIFTOUT Dpin,Clock,MSBFirst,[noparse][[/noparse]col,d7219]
PULSOUT Load,3
NEXT
RETURN
wired up. Have you tested the display by hand to see if the pins do what
they should?
> I'm attempting to impliment Nuts and Volts article #70 which drives a 5X7
be
that
the
BS2.
Matrix match the pinouts in the article. I tested everything by hand and it
works fine. If it were a pinout problem I would expect a single light, or
maybe two to not cooperate, but two full lines? That would mean that
several Anode/Cathode lines are high.
Any other suggestions?
Any chance Mr. Jon Williams (article author) has any ideas?
Matt
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9lQnOr7xXvOvpVBO47vIMRxdnYb8CNNA2syZBW_oI8SDncBh83FhUpnUcjU0x-s3JldAuq79hO_3XXnu]daweasel@s...[/url
Sent: Monday, August 05, 2002 6:07 PM
Subject: Re: [noparse][[/noparse]basicstamps] MAX7219 Help
Sounds to me like the pinout on the display may not match what you have
they should?
be
that
the
BS2.
mgeorgy@d... writes:
There is the chance that I erred in transposing the schematic from my
breadboard to the column, but since its publication I haven't had any
complaints about it until now. I'm sure a quick look at the MAX7219 data
sheet and your setup would confirm my error or yours.
-- Jon Williams
PS: Okay, I'm 40 ... but I hate being called "Mr."
Of course your Alzheimer's may have kicked in -- that article was a few
years ago.
Remind me at the meeting to show you what I put together from that article.
> -- Jon Williams
