Array with b5, b6, b7....b15
Hi Group
It is probably an easy Question but I don' see the answer:
How con I declare an array "manually"?
Instead of :
"Temp var byte(10)"
I would like to say something like:
"Temp var ....b5 to b15..."
to tell the compiler to use location b5 to b15
(for easy use in multiple slots)
and my update-loop below should still work
Thankful for an answer
Regards, Heinz Schwenk Germany
Temp var byte(10)
update:
for loop=9 to 1
Temp(loop)=Temp(loop-1) 'Temp0=newTemp, Temp1=Temp0 ,
Temp2=Temp1,......
Debug ? loop, ? Temp(loop)
next
Pause 2000
goto update
Instead of :
"Temp var byte(10)"
Temp var byte(10)
update:
for loop=9 to 1
Temp2=Temp1,......
next
Pause 2000
goto update
have to since PBASIC memory works as an array anyway. Let me say first that
I STRONGLY recommend you NOT using internal variable names -- I believe it's
better to delcare an array as you need it and let the compiler organize the
variable RAM.
That said, you can access P5 .. P15 with a simple pointer, indexed from B0
pntr VAR Nib
' clear the array
FOR pntr = 5 TO 15
B0(pntr) = 0
NEXT
' or like this:
FOR pntr = 0 TO 10
B5(pntr) = 0
NEXT
-- Jon Williams
-- Parallax
In a message dated 3/30/02 3:54:09 AM Central Standard Time, hschwenk@g...
writes:
> Hi Group
> Instead of :
> "Temp var byte(10)"
> Temp var byte(10)
> update:
> for loop=9 to 1
> Temp2=Temp1,......
> next
> Pause 2000
> goto update
I understand this:
FOR pntr = 0 TO 10
B5(pntr) = 0
NEXT
But w h e y not using internal variable names --
If I use and change "global Variables" in different slots
I don't need to think about saving them al the time ?
What is the disadvantage of using internal variable names?
I may don't see the point ?
Have a nice and happy easter,
Thanks Heinz Germany
> You can't declare an array of [noparse][[/noparse]internal] PBASIC variable names and you don't
> variable RAM.
> pntr VAR Nib
> ' clear the array
> FOR pntr = 5 TO 15
> B0(pntr) = 0
> NEXT
> ' or like this:
> FOR pntr = 0 TO 10
> B5(pntr) = 0
> NEXT
> -- Jon Williams
> -- Parallax
> writes:
> > Hi Group
> > Instead of :
> > "Temp var byte(10)"
> > Temp var byte(10)
> > update:
> > for loop=9 to 1
> > Temp2=Temp1,......
> > next
> > Pause 2000
> > goto update
of the
message will be ignored.
writes:
Because, depending on the complexity of your program and other variable
definitions, using internal variable names can lead to conflicts and
inefficient memory use.
B0 .. B25 (W0 .. W12) are PHYSICAL locations in the Stamp's memory. Do you
really care where your variables are located? The only time I suggest using
internal names is when you want to clear all variables in the middle of a
program. You can do it like this:
FOR W12 = 0 TO 11
W0(W12) = 0
NEXT
W12 = 0
-- Jon Williams
-- Parallax
>Instead of :
> "Temp var byte(10)"
Hi Heinz ,
Like Jon, I prefer to let the compiler allocate space for the
variables, rather than using the predefined variables. As you know
already, it is more of a problem when you have a multibank stamp with
its multiple program slots. No matter how you do it, it takes
planning.
One trick is to realize that the compiler always allocates space to
word variables first, before any of the bytes, nibs or bits.
Therefore, to have everything come out in a set place, you can define
all of your "globals" as words. You have to define them first in
every slot. Furthermore, if you need (probably) "global" bytes, nibs
and bits, you have to define them as aliases within those words so
that they too will come out in the "protected" space. The beauty of
that is, that _after_ the "globals" within each individual slot, you
can proceed to define as many "local" words, bytes, nibs and bits as
you need and they will not overlap the "protected" variables.
For example, if you have a "global" array that takes 11 bytes, and 1
global nib and 4 "global flag" bits, you could define the following 6
word variables in every slot:
glob0 var word
glob1 var word
glob2 var word
glob3 var word
glob4 var word
glob5 var word
crunch var glob0.byte0 ' for 11 byte array addressed as crunch(i)
i var glob5.nib2 ' nibble for global index
flags var glob5.nib3 ' nibble for global flag bits
flag0 var flags.bit0 ' a flag bit and so on
Then you can define any "local" variables you want _after_ those globals:
tempword var word
temp var byte(10)
tempbi var bit
I have some more info on my techniques with the multibank stamps at
http://www.emesystems.com/BS2SX.htm
-- regards,
Tracy Allen
mailto:tracy@e...
Thanks a lot, it's nice to get these detailed answers **!!!
regards Heinz
> >Instead of :
> > "Temp var byte(10)"
> Hi Heinz ,
> planning.
> glob0 var word
> glob1 var word
> glob2 var word
> glob3 var word
> glob4 var word
> glob5 var word
> tempword var word
> temp var byte(10)
> tempbi var bit
> -- regards,
> Tracy Allen
> mailto:tracy@e...
of the
