basic stamp 1 programming connections
What would a list be without stupid questions from newbies!
I am new to the basic stamp but not to tinkering with electronics. I
can't seem to program the basic stamp 1 that I just got.
I followed the wiring digram for programming the stamp and did
continuity tests on my cable but I can't seem to get my stupid "hello
world" program to download to the stamp.
here is my connection information
parrallel port stamp pin
pin 25 pin 2
pin 11 pin 3
pin 2 pin 4
The only thing the diagram doesn't say is where to connect power!
But, I assumed (bad idea) that I should connect my 9v battery ground to
pin
25 which is the parrallel ports ground and the positive lead to pin 1
of the stamp. Is this correct? If it is then why is it that when I
connect the stamp to the computer and hit alt-r the program tells me
that the "hardware [noparse][[/noparse]is] not found".
Please help!
Steven
pin 25 pin 2
pin 11 pin 3
pin 2 pin 4
pin
Please help!
Steven
that right.
Are you running the Stamp I software? Under DOS or Windows? Some people
have trouble running it under Windows. It certainly doesn't run under
Windows NT/2000/XP.
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: Steven Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7_boXE4MxgkxWqmoNT1ThzRRMHFYq1Wri8fkiKrK9O7efoWtljmPVYHU8InGeLohWJsZ-SFXr5pcbXeNeYAS]cmmdrdata@c...[/url
> Sent: Tuesday, March 26, 2002 8:13 PM
> Subject: [noparse][[/noparse]basicstamps] basic stamp 1 programming connections
> did continuity tests on my cable but I can't seem to get my
> stupid "hello world" program to download to the stamp. here
> pin 25 pin 2
> pin 11 pin 3
> pin 2 pin 4
> power! But, I assumed (bad idea) that I should connect my 9v
> battery ground to pin 25 which is the parrallel ports ground
> tells me that the "hardware [noparse][[/noparse]is] not found".
> Please help!
> Steven
> from the same email address that you subscribed. Text in the
have any configuration steps, so I
figure it should work out of the box.. so to speak. Do you recall what ground
on the 9v should be connected to?
Steven
Al Williams wrote:
> If I recall, yes... Pin 1 is Vin. You should see 5V on pin 5 if you have
> that right.
> Windows NT/2000/XP.
> Al Williams
> AWC
> > From: Steven Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BzAqjUO0Rp3Suk-IgVAZVilgylLUUZTUj4SstxdUTX7FnC7x4XTgEL6xH_UvNkr1LDmMfc8X8TI548019g]cmmdrdata@c...[/url
> > pin 25 pin 2
> > pin 11 pin 3
> > pin 2 pin 4
> > Please help!
> > Steven
computer or printer port to try it on?
Al Williams
AWC
* 8 channels of PWM
http://www.al-williams.com/awce/pak5.htm
> From: Steven Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hVNTcjSv07XYmw2kpf0HKiEvWaYcVVoQ2EpAN9ZXrRAjAGcUX6I82GDAZSUTUVQws_Tqq370x1glWDk]cmmdrdata@c...[/url
> Sent: Tuesday, March 26, 2002 9:21 PM
> Subject: Re: [noparse][[/noparse]basicstamps] basic stamp 1 programming connections
> under Dos. I don't know what is wrong with this thing. The
> software doesn't have any configuration steps, so I
> recall what ground on the 9v should be connected to?
> Thanks,
> Steven
> > have that right.
> > people have trouble running it under Windows. It certainly
> doesn't run
> > under Windows NT/2000/XP.
> > Al Williams
> > AWC
> > * Floating point A/D http://www.al-williams.com/awce/pak9.htm
> electronics. I
> > > can't seem to program the basic stamp 1 that I just got. I
> > > "hello world" program to download to the stamp. here is my
> > > pin 25 pin 2
> > > pin 11 pin 3
> > > pin 2 pin 4
> battery ground
> > > to pin 25 which is the parrallel ports ground and the
> positive lead
> > > to pin 1
> that when I
> program tells me
> > > Please help!
> > > Steven
> the Subject
[noparse]:([/noparse] Am I hosed or what?
Al Williams wrote:
> Pin 2 should be ground. Do you have 5V on pin 5? Do you have a different
> Al Williams
> AWC
> * 8 channels of PWM
> > From: Steven Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zkMrViIaNTjoxAHpFk6ojIfmq7RQJNmkaqa2F61ZNWTG2aNVO-_c-3_DFtvXHg6h3k_x_1Q_GIAhLhc]cmmdrdata@c...[/url
> > Thanks,
> > Steven
> > > have that right.
> > doesn't run
> > > Al Williams
> > > AWC
> > electronics. I
> > > > pin 25 pin 2
> > > > pin 11 pin 3
> > > > pin 2 pin 4
> > battery ground
> > positive lead
> > > > to pin 1
> > that when I
> > program tells me
> > > > Please help!
> > > > Steven
> > the Subject
Assuming you have the Stamp powered up correctly, are you sure your printer
port is available in DOS?
On some PC's the ports don't exist except in Windows -- strange stuff.
Anyhow, this is how you tell:
Boot up in DOS or restart in DOS from Windows
At the DOS prompt, type DEBUG and press enter -- you will see a "-" prompt.
Type D0:0400 and press enter -- those are zeros and not the letter O! A
whole mess of numbers will be displayed.
The first line should begin with 0000:0400 -- there are 8 groups of two
characters and a dash -- these represent the serial ports found in DOS.
After the dash is where you find the parallel ports DOS knows about -- LPT1
would show up as 78 03 in the first two pairs of characters. Likewise LPT2
would show up as 78 02 in the second two pairs of characters.
If its not there, it does not exist in DOS. If its got the wrong address --
ie the first two pairs are not 78 03 -- you need to be sure the parallel
port is hard-coded to an address in the BIOS and not set to auto.
> Yeah, I checked and I have 5v on pin 5. I tried it on my wife's computer
also [noparse]:([/noparse] Am I hosed or what?
> > > > have that right.
> > > doesn't run
> > > electronics. I
> > > > > pin 25 pin 2
> > > > > pin 11 pin 3
> > > > > pin 2 pin 4
0000:0400 F8 03 F8 02 00 00 00 00-78 02 00 00 00 00 00 00
Looks like LPT2 is available in DOS. Does the parallel port have to be
bi-directional for this thing to work?
What are my other options? The windows version is only for BS2 right?
Rodent wrote:
> Charles E. Fromage says:
> > > > > have that right.
> > > > doesn't run
> > > > electronics. I
> > > > > > pin 25 pin 2
> > > > > > pin 11 pin 3
> > > > > > pin 2 pin 4
Sent: Tuesday, March 26, 2002 6:13 PM
> pin 25 pin 2
> pin 11 pin 3
> pin 2 pin 4
> pin
> Please help!
> Steven
command line...
Al Williams
AWC
* 8 channels of PWM
> From: Steven Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=G-8cJQdQePOyOyRm_dwf7sollzrceKjU_WwSla714BCd96qO3ZSFYrGEz_i10x2yEuCUcHg_KkRYn8Q]cmmdrdata@c...[/url
> Sent: Tuesday, March 26, 2002 10:28 PM
> This is what I got:
> port have to be bi-directional for this thing to work?
> BS2 right?
> > printer port is available in DOS?
> strange stuff.
> > prompt.
> letter O!
> > A whole mess of numbers will be displayed.
> > two characters and a dash -- these represent the serial
> ports found in
> > DOS.
> knows about --
> > LPT1 would show up as 78 03 in the first two pairs of characters.
> > Likewise LPT2 would show up as 78 02 in the second two pairs of
> > characters.
> > address -- ie the first two pairs are not 78 03 -- you need
> to be sure
> > the parallel port is hard-coded to an address in the BIOS
> and not set
> > to auto.
> > > computer
> > > > different computer or printer port to try it on?
> on pin 5
> > > > > > if you have that right.
> > > > > > Some people have trouble running it under Windows. It
> > > > > > certainly
> > > > > doesn't run
> from newbies!
> > > > > electronics. I
> just got. I
> stamp and did
> stamp. here
> > > > > > > pin 25 pin 2
> > > > > > > pin 11 pin 3
> > > > > > > pin 2 pin 4
> the Subject
their cables.
Stephen H Chapman wrote:
> Read the Stamp Manual.
> From: "Steven Johnson" <cmmdrdata@c...>
> > pin 25 pin 2
> > pin 11 pin 3
> > pin 2 pin 4
> > pin
> > Please help!
> > Steven
Parallel Port ?
regards,
Leroy
> pin 25 pin 2
> pin 11 pin 3
> pin 2 pin 4
> pin
> Please help!
> Steven
/ BIOS settings and make sure LPT1 is set to 0378 and not AUTO -- when its
in auto, Windoze does the configuration and the port works in Windows and
not in DOS.
As far as I know, there is no Windows editor for the BS1.
> This is what I got:
printer
