This is a good question to ask, "What do you really want to do?"
I don't know of a processor -- even an SX -- that could do what you
want. Do you mean you want to FM modulate a 100MHz carrier (FM wireless
mike type transmitter)? If so, that might be a different answer than
Jon's "No".
If you really mean can I generate a frequency varying signal centered on
100MHz then the answer is, in fact, no. But I have a feeling if you tell
the list _what_ you want to do instead of _how_ you want to do it, we
might be able to help you more.
-- Jon Williams
-- Parallax
In a message dated 3/26/02 3:17:40 PM Central Standard Time,
nevinlaura@y... writes:
> Is it possible to perform frequency modulation in the 100 MHz range using a
> BS2p?
Jon's "No".
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: nevinlaura [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xFZzt1uaZ1reLjlReeae_1ShODLYdYXtfWHBhggX8B2q3Uw3ws4v9Fn5Vz0eje7qbTnfGt3qJuPeQ38]nevinlaura@y...[/url
> Sent: Tuesday, March 26, 2002 11:15 AM
> Subject: [noparse][[/noparse]basicstamps] Frequency Modulation
> range using a BS2p? If so, How?
> Thanks
> Nevin
> from the same email address that you subscribed. Text in the
