Serial Communication
I need some kind of program or advice on how to write some kind of
program that will allow me to send characters or character strings
through the serial port. Anything to do with C++ or visual basic i
can understand. I was thinking about using the C++ bios.h file and
its functions to go about doing this. Is this a good idea?
with C++ or Visual Basic.
I think www.rentron.com has some serial examples. Plenty of serial
advice at www.lvr.com also.
I would not use bios.h unless I was under DOS. In Windows you may have
lots of serial ports the bios doesn't know about (the machine I am using
right now has 10 com ports...)
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
> From: compsci2522003 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3aNn95od-1EF6fSyBUX37lBIJXY1gbNCzsZ59B6DTWuH5s7TAr1eQhQ4c1yYLX-wtHwRm_fBWDDZzPdmcEWPQQ]waseemthedream@h...[/url
> Sent: Monday, March 25, 2002 9:21 PM
> Subject: [noparse][[/noparse]basicstamps] Serial Communication
> from the same email address that you subscribed. Text in the
I have a question concerning serial communication. I am working on a project
involving a CMU-cam that sends serial data to the stamp. The lowest baudrate
the CMU can handle is the highest that the stamp can handle. I got it
working somehow but very often the data are corrupted like parts of it
missing or sometimes even nothing appears.
Is there any chance to put a BAUD-SLOWER between the stamp and the cmu?
(isn't that a nice word? :-)
I am not depending on speed in that project. so 2400b would be perfectly ok
for me.
Thanks for any suggestions,
Uli
>Good morning Stampers,
>for me.
>Uli
>Uli-
What is the baud rate of the CMU-cam ?
Bruce Bates
and thus can better handle the high baud rates.
second you probably should look at the electrical characteristics of
your circuitry: shielding, grounding layout, cable lengths, etc.
maybe a memory buffer between the cam and the stamp may help. The
buffer should be big enough to hold one full image at least.
In the early times such buffers were popular for printers.
regards
adrian
baud for serial communication (default is 115,200). Perhaps that is your
problem if your using 9600 baud.
From: ulibasic [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tm6TKdQwfGItoI8GEmxZRDQ0MlChDAjROrelvO9tHyfVhO_P0WLj1k8r0tnVN6fhhv3OHfGjZQqajl6ilnusLY1Nbv1PBIX4]ulibasic@r...[/url
Sent: Thursday, November 21, 2002 3:26 AM
Subject: AW: [noparse][[/noparse]basicstamps] serial communication
Hi Bruce, it is 9600 baud
Bruce Bates
communication by using a visual basic 6 window
program. Need to know if there is any existing
program that I can use, rather than reinventing the
wheel. Thank you for any help that I can get.
George
__________________________________
Do you Yahoo!?
Yahoo! Calendar - Free online calendar with sync to Outlook(TM).
http://calendar.yahoo.com
latest [noparse][[/noparse]best information] is column #89: Data Exchange With Visual Basic.
-- Jon Williams
-- Parallax
In a message dated 6/12/2003 2:11:13 AM Central Standard Time,
gyan48@y... writes:
> Trying to make BS2 to talk to PC via serial
> George
9600, Odd, 1, 8 Communication Parameters for the Basic-Stamp II.
Didn´t expected to ask such a difficult Question.
Can ANYBODY help me???
I Need a solution between Basic-Stamp II and a Converter for the ODD
Parity Problem.
The Max 232 Only Handles the 5V-TTL to 12V-IEE433 Problem.
I need something like a Buffer for 8 Bits In-Buffer and out 9 Bits
with ODD Parity. Software-Control ist about too risky for me (but if
it´s working..), I think more about a Hardware-Solution.
thanks in common
Alex
modes don't support ODD parity. They only support
8-bit No, and 7-bit Even.
You may have to go to a true UART chip. I'd recommend
the Maxim 3110 chip. It is a 28-pin narrow DIP, with
an SPI interface to the Stamp. You need a 3.6864 MHz
crystal to go with it, with two tiny 10 pF caps.
With this package, you get a true send/receive UART,
and no-extra-capacitor RS232 2 drivers/2 recievers.
Having just looked at the data sheet, there
is a problem. If you want ODD parity, you'll have
to calculate the parity bit yourself. The 3110 will
support SENDING the parity bit, but it won't
automatically calculate the parity bit. You could
use a long 'lookup' command to find the ODD parity
bit for a given byte.
It does have an 8-bit buffer, so your BS2 can do
other things besides just taking data.
--- In basicstamps@yahoogroups.com, "harveyhase68" <yahoo@p...> wrote:
> On 18.Juni I asked for a Hint for a:
ODD
> Parity Problem.
if
> thanks in common
> Alex
If you get to choose what will be transmitted, your Stamp can do
this, in effect. Essentially, you must only transmit bytes with even
parity over the 8 bits of the byte itself. The stop bit generated
by the Stamp, when interpreted by your receiving device as a parity
bit, will then create an odd parity over the perceived data+parity
bits, and the follow-on idle line will serve as a stop bit. Use the
PACE argument if needed to ensure adequate idle time following the
"real" stop bit.
Otherwise you're probably looking at a custom, external solution.
Steve
presentation at our museum (Shreveport LA)and trying to turn it on
and off using a BS2. I tried wiring directly into the remote
control and with the help of simple reed relay but it is not very
reliable.
The LP280 has an RS232 port but the command structure is very
confusing. According to their manual:
The message sent to the projector is divided into a header(7 bytes)
and a body part(6 bytes)
The message has the following structure:
Magic Number Body Size CRC
0xBE 0xEF 0x80 0xo6 0x00 CRC_Lo CRC_Hi
The Body has the following structure
Operation Type Function Value
OpTypeLo 0x00 funcNum_Io Opval_lo Opval_hi
And, according to the manual again, the command to turn power on
should be:
0xBE 0xEF 0x80 0x06 0x00 0x00 0x00 0x01 0x00 0x01 0x00 0x01 0x00
My main question is what the heck is the "0x" preceeding each byte.
The second question, how would I send this long command, should I
just enclose it in hyphens and send it?
Any help deciphering this would be most appreciated
Al
0x indicates that the commands are in HEX numerical code. You cannot
enclose them in Quotes like "". Quotes indicates to the Stamp to send its
data out as readable ASCII text that a person can read.
If this group cannot help you or you cannot seem to get it together, my I
sugges calling Louisiana Tech in Ruston. I went there. The Engineering
Dept. may be able to get a student to help you.
Brian
> the command to turn power on should be:
Put it in EEPROM with a data directive, and then read and send it one byte
at a time. The data directive and a loop to read the values from EEPROM
would look like this:
PowerOnCmd DATA $BE, $EF, $80, $06, $00, $00, $00, $01, $00, $01, $00, $01,
$00
ThisCmdByte VAR Byte
Pos VAR Nib
[noparse][[/noparse] Main
Code ]
Main:
FOR pos=0 TO 12
READ PowerOnCmd+Pos, ThisCmdByte
DEBUG HEX2(ThisCmdByte)," "
NEXT
END
This just displays the value, and note that the HEX2() function is changing
those hexadecimal values in EEPROM into characters we expect to see. The raw
values would look like command bytes to the debug terminal and would not
display properly. You don't want that with your SEROUT command. Just send
the bits as they are in the variable ThisCmdByte. Of course you can change
all those labels to be anything you like. (I'm too lazy to work out the
details of the SEROUT command, which I haven't gotten around to needing yet,
but take away the HEX2 when you do that yourself.)
The dollar sign is PBASIC's way of indicating that the characters that
follow are to be interpreted as a hexadecimal value. The 0x is another
convention for the same purpose.
Gary
--- In basicstamps@yahoogroups.com, "Gary W. Sims" <simsgw@c...>
wrote:
> From: "brownstamp" <brownstamp@y...>
byte.
one byte
EEPROM
$00, $01,
> $00
> Pos VAR Nib
> Code ]
> Main:
> FOR pos=0 TO 12
> NEXT
> END
changing
see. The raw
would not
Just send
can change
out the
needing yet,
that
another
> Gary
you know the baud parameters you can send it out with SEROUT:
Projector_On:
SEROUT Spin, Baud, [noparse][[/noparse]$BE, $EF, $80, $06, $00, $00, $00, $01, $00, $01,
$00, $01, $00]
Please consult the BASIC Stamp help file or manual for specifics on
using SEROUT and setting the baud rate.
-- Jon Williams
-- Dallas Office
From: brownstamp [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NMsl01UgWeVyEnoNKF5yRLq7QyliBM0_n3txP9jzhRfle90ZzYAQMXafhHngGh59ZE_p2nJiHvqL5DWCsFiP]brownstamp@y...[/url
Sent: Monday, November 03, 2003 10:23 PM
Subject: [noparse][[/noparse]basicstamps] Serial communication
I have an Infocus LP280 projector that I use in a multimedia
reliable.
should be:
Al
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
171. You can use the calulator that comes with windows to
convert it if needed..
In most forms of basic, you would use the command chr(171)
to send send it out. In PBasic use 'dec 171' in the serout
or debug command. See the documentation for this.
Regards
Dave Evartt
American Hovercraft
I'm new to basic stamps and was wondering if anyone can answer a
short question for me. Can a basic stamp2 communicate serially
using I2c of SPI?
Thanks in advance for any responses I get.
David
clock) with any BS2-family module using the SHIFTOUT and SHIFTIN
instructions. The BS2p and BS2pe modules have built-in commands for I2C
(I2COUT and I2CIN) and again, the BASIC Stamp is the master. You can do
I2C with non-BS2p/pe BASIC Stamp modules, but it requires a bit of code.
It's not tough, though, I've done it and have made my library of I2C
routines available for anybody who wants them.
-- Jon Williams
-- Dallas Office
From: David Dupont [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7ksK1Iomg7El8AFAd0LoG0IEMFrYhnHTXniIqwg5sBEnXNN2hmXVXe4rfoLNvByNYGl5VF6SF8CKDbv4wg]dldupont@Q...[/url
Sent: Monday, June 28, 2004 7:32 PM
Hey everybody,
using I2c of SPI?
David
SHIFTIN and SHIFTOUT commands.
I believe only the BS2p variants can use I2C
directly, but I think there are way to use
a BS2 with I2c in the Nut&Volts section.
--- In basicstamps@yahoogroups.com, "David Dupont" <dldupont@Q...>
wrote:
> Hey everybody,
> using I2c of SPI?
> David
