Pbasic Varables
I would like to learn about the Pbasic Variables for the stamp. Is
there a place that would list the variations and give examples of each?
I have the stamp editor version 1.3 and couldn't find anything there.
It would be nice is I could get some comparisons to BASICA or GW BASIC,
I know those pretty well. Suggestions please..
thanks for your help.
Leroy
Leroy
Sid
Stamp Manual from Parallax, or at least a portion of it.
Sid
variables.
Here's some quick stuff:
PBASIC variables are limited (26 bytes) but incredibly flexible. You can
define variables as word (16-bit), byte (8-bit), nib (4-bit) and bit. You
simply declare your variable and its type; the compiler takes care of
allocating RAM. With this much type flexibility, the 26 bytes can go a long
way.
For example, if you have a counter that goes from 0 to 9, there's no reason
to declare it a byte or word since for bits (0..15) will handle it.
The compiler allows you to alias (rename / reuse) variables or even portions
of them. For example:
flags VAR Byte
overTmp VAR flags.Bit7
You can now deal with a variable called overTmp which is, of course, pointing
to the msb of flags.
One last tidbit that isn't really explained anywhere (in depth). All Stamp
memory is an implicit array. Example:
manny VAR Byte
moe VAR Byte
jack VAR Byte
x VAR Nib
FOR x = 0 TO 2
manny(x) = $FF
NEXT
You can access bits in a nib, byte or word with LowBit(x). Likewise, nibbles
in a byte or word with LowNib(x) and, finally, bytes in a word with
LowByte(x).
FOR x = 0 TO 7
manny.LowBit(x) = 1
NEXT
HTH ... or, at least, piques your interest.
-- Jon Williams
In a message dated 3/24/02 11:50:23 AM Central Standard Time, leroy@f...
writes:
Thanks in advance so much for your response and yes your comments did
seem rather interesting. I looked through the portions of the manual
that discusses variables and seen reference to much of what you said
below. The bits, bytes, and nibbles I am ok with, the array is the part
about the following code that is still a bit foggy:
Stamp memory is an implicit array.
Example:
manny VAR Byte
moe VAR Byte
jack VAR Byte
x VAR Nib
FOR x = 0 TO 2
manny(x) = $FF
NEXT
thanks again,
Leroy
I'm not sure how else to follow up -- doing some simple experiments (like I
illustrated below) is probably the best way to clarify this for yourself.
One thing I can add the pertains to the Manny-Moe-Jack example is that it
works because all three variables are the same type and declared in a
specific order. The compiler arranges variables by size, starting with
words, then bytes, then nibs and finally, bits -- and then in the order they
appear in your declarations section. If you declare several variables of the
same type [noparse][[/noparse]in order], you can treat them as an array of the first item. Like
this:
counters VAR Byte
counter0 VAR counters ' counter0 occupies same location as
counters
counter1 VAR Byte ' counter1 occupies location after
counter0
counter2 VAR Byte
counter3 VAR Byte
These two lines of code accomplish the same thing:
counters(2) = 10
counter2 = 10
Why would you want to do variables manually instead of declaring an array?:
counters VAR Byte(4)
Because PBASIC won't let you alias to an array element and sometimes that is
a useful thing to do, so the technique presented above handles it.
This is legal (referencing the declarations above):
redCount VAR counter0 ' occupies same location as counter0
grnCount VAR counter1
bluCount VAR counter2
blkCount VAR counter3
This is not:
redCount VAR counter(0)
grnCount VAR counter(1)
bluCount VAR counter(2)
blkCount VAR counter(3)
...because an array index cannot be used in a variable declaration.
Using the aliases, like I did above, can make the program a little more
readable. Sure, it's a bit more work on setup, but I think it's worth it.
In the end, though, the declaration would be simplest like this:
counters VAR Byte
redCount VAR counters ' redCount is same as counters(0)
grnCount VAR Byte
bluCount VAR Byte
blkCount VAR Byte
Now, these two lines of code do the same thing:
counters(3) = 0
blkCount = 0
... and I can use the array to set all values in a loop:
FOR x = 0 TO 3
counters(x) = 10
NEXT
... and
DEBUG DEC redCount
... displays "10" on the DEBUG screen.
So ... in general, a PBASIC program will allow you to add an array index
(parenthesis) to ANY variable [noparse][[/noparse]except in a declaration] -- even if it wasn't
explicitly declared an array. The index will offset into the Stamp's memory
from the [noparse][[/noparse]physical] location of the variable (0 = no offset).
I hope this has helps lift the fog a bit and has not made it thicker....
-- Jon Williams
In a message dated 3/29/02 2:53:31 AM Central Standard Time, leroy@f...
writes:
> Dear Jon,
> Example:
> manny VAR Byte
> moe VAR Byte
> jack VAR Byte
> x VAR Nib
> FOR x = 0 TO 2
> manny(x) = $FF
> NEXT
> thanks again,
> Leroy
Thanks so much for your response and assistance about my variable
questions. Here's a couple of more for you:
Here's the program you suggested (or close save the debug's):
'{$STAMP BS2}
manny VAR Byte
moe VAR Byte
jack VAR Byte
x VAR Nib
FOR x = 0 TO 2
manny(x) = $F0
NEXT
DEBUG bin manny
debug cr
DEBUG bin moe
debug cr
DEBUG bin jack
Two questions:
1.) Looks like all three variables get the same values i.e. 1111 0000
or hex f0. Why do I need separate names? This seems rather useless
unless I am missing a point. That is, "why would I want to store a
number in the variable manny and then have the same number also appear
in moe & jack"?
2.) Let's say I have the following:
'{$STAMP BS2}
manny VAR Byte
moe VAR Byte
These are byte variables i.e. they are 8 bits wide or
B7 B6 B5 B4 B3 B2 B1 B0
Is it possible for me to move bits: B7 B6 B5 B4 of the variable manny
into B3 B2 B1 B0 of the variable moe?
Can I move bit 6 of manny into bit 2 of moe?
thanks so much for your help. I hope to master this variable thing
soon.
Happy easter,
Leroy
All of this has to do with a programmer's style. On to your questions:
(1) Of course, you don't have to have separate names, but I find on many
occassions that separate names make my code easier to read and maintain. I
work hard to make my code easy to read (for others) and maintain (for me).
(2) This is where the variable modifiers help. You can do this.
moe.LowNib = manny.HighNib
Moving something other than 1, 4 or 8 bits requires a bit of math or logical
operations. Let's say you want to move the upper six bits of manny into the
lower six bits of moe. The upper two bits of moe must be maintained. This
is one way do it:
moe = (moe & %11000000) | (manny >> 2)
Please consult the manual if some of these operators are new to you.
-- Jon Williams
-- Parallax
In a message dated 3/30/02 11:44:08 AM Central Standard Time, leroy@f...
writes:
> Dear Jon,
> '{$STAMP BS2}
> manny VAR Byte
> moe VAR Byte
> jack VAR Byte
> x VAR Nib
> FOR x = 0 TO 2
> manny(x) = $F0
> NEXT
> DEBUG bin manny
> debug cr
> DEBUG bin moe
> debug cr
> DEBUG bin jack
> Two questions:
> in moe & jack"?
> '{$STAMP BS2}
> manny VAR Byte
> moe VAR Byte
> soon.
> Happy easter,
manny VAR Byte
moe VAR Byte
jack VAR Byte
x VAR Nib
So with the above definitions / declarations
manny(0) = manny
manny(1) = moe
Manny(2) = jack
If I am on the right track here, this seems very confusing.. I.E. in
GWBASIC once an array is defined, each defined sections of that array
are separate entities. Such as an array defined as manny(10) has ten
elements that are all a byte or a word wide and are called manny(0)
through manny(10).
thanks,
Leroy
BASIC with far fewer resources than any PC-oriented BASIC would have. The
BASIC Stamp designer (ironically, a guy named "Chip") created an incredibly
flexible memory architecture to help engineers manage complex tasks with few
resources.
You can, of course, do as you suggested and define a standard array as you
would in GWBASIC.
manny VAR Byte(4)
Doing it this way, you always have to refer to manny(0), manny(1), etc. This
is fine. Sometimes, though, I find the implicit array capability and
aliasing variables makes my code easier to read.
Again:
counters VAR Byte
grnCount VAR Byte
bluCount VAR Byte
blkCount VAR Byte
In my opinion, using:
grnCount = 3
...is more clear than:
counters(1) = 3
Of course, there are many ways to skin a cat. If you want to stick to PC
conventions, you could add this.
Red CON 0
Green CON 1
Blue CON 2
Black CON 3
Now, you could do this:
counters(Green) = 3
...and the code becomes very readable and easy to maintain.
In the end, there are only 26 bytes of user RAM. Variable aliasing
(renaming) is one part of PBASIC that I find particularly helpful -- and
often find myself wishing I had the same flexibility with my PC programs.
-- Jon Williams
-- Parallax
In a message dated 3/30/02 12:28:17 PM Central Standard Time, leroy@f...
writes:
> '{$STAMP BS2}
> manny VAR Byte
> moe VAR Byte
> jack VAR Byte
> x VAR Nib
> manny(0) = manny
> manny(1) = moe
> Manny(2) = jack
> through manny(10).
In English this says: moe = (moe AND %11000000 OR (manny (Logical Shift
right by 2)))
Does this:
Let's say moe= 0001 1011
Let's say manny = 0111 1011
if I AND moe with %1100 0000 I get 0000 0000
If I logical shift right manny by 2 I get 0001 1110
If I then Bitwise OR 0000 0000 with 0001 1110 I get 0001 1110 and this
value get placed in moe
This look right?
thanks,
Leroy
logical operations. Let's say you want to move the upper six bits of
manny into the lower six bits of moe. The upper two bits of moe must be
maintained. This is one way do it:
of code and using DEBUG statements along the way to show you the status of
things.
Just be aware that there is a difference between bit-wise operators and
logical operators.
-- Jon Williams
-- Parallax
In a message dated 3/30/02 3:56:19 PM Central Standard Time, leroy@f...
writes:
> Your example:
> right by 2)))
> Does this:
> This look right?
> thanks,
These byte variables i.e. they are 8 bits wide or
Suppose we have this:
manny VAR Byte
is it possible to output B3 B2 B1 B0 to pins 4 5 6 7, or must I do it
one pin at a time?
thanks in advance for your help..
Leroy
The architecture of the PIC and SX chips causes the I/O pins to behave like
variables. The BASIC Stamp has three (16-bit) variables that are associated
with I/O pins: Dirs (pin directions), Outs (outputs) and Ins (inputs).
All three variables are conveniently aliased into managable chunks (bytes,
nibbles and bits). Dirs, for example:
Dirs (16 bits)
DirL and DirH (8-bits ea.)
DirA, DirB, DirC and DirD (4 bits ea.)
Dir0 .. Dir15 (1 bit ea.)
The same holds true for Ins and Outs.
To get to your specific question, first you need to set Pins 4 - 7 as
outputs. Here's how:
DirB = %1111
Then you can do this:
statusLeds VAR OutB ' alias for output
pins 4 - 7
manny VAR Byte
.. finally...
statusLeds = manny.LowNib
Actually, the LowNib modifier isn't required -- since statusLeds is only
four-bits wide the program will take the lower four bits of manny. It's best
to be clear though.
HTH.
-- Jon Williams
-- Parallax
In a message dated 3/30/02 9:55:23 PM Central Standard Time, leroy@f...
writes:
> Dear Jon,
> manny VAR Byte
> one pin at a time?
