Battery Question... — Parallax Forums
Battery Question...
edited 2002-04-01 19:20 in General Discussion
This is kind of a more generic electronics question, but since I know you
all are pretty smart from previous stamp questions I have asked, I thought
you could give me a good answer:
I bought a stereo boom box that takes 6 "D" size batteries (1.5v). Can I
modify it to use a 9.6v R/C Car battery like you find at radio shack? I
know that with the batteries it would be 9 volt and with the car battery
it would be 9.6v but does .6 really matter? also, is there anything I
would have to worry about regarding amperage? is it true that amperage
doesnt matter because the device will always pull whatever it needs so you
cant burn it out? what other issues may be a problem in doing this
conversion?
- Matt
    edited 2002-03-24 17:56
    Yeah, the reason I thought of it is because it is cheaper then buying
    rechargable D batteries and I already have a 9.6 battery and charger out
    at the flying field (where the boom box will be). It doesnt matter if it
    runs down sooner because those packs take 15 minutes to charge.
    - Matt
    On Sun, 24 Mar 2002, Leroy Hall wrote:
    > I don't think the .6 volt will give you a problem. Actually your idea
    > is a very good one. The 'D' size batteries have a higher amperage
    > rating, than the 'C' or 'A' size that you will find in the rechargeable
    > packs, but that's OK. The smaller size will run down faster, never the
    > less they in my opinion will work fine. The ability to recharge will
    > bring many benefits.
    > leroy
    > > conversion?
    > > - Matt
    > > To UNSUBSCRIBE, just send mail to:
    > > basicstamps-unsubscribe@yahoogroups.com
    > > from the same email address that you subscribed. Text in the Subject and
    > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2002-03-24 18:02
    leroy
    > conversion?
    > - Matt
    edited 2002-03-29 14:20
    You are generally correct in your statements. You should have no problems
    with the 9.6 v R/C battery as long as it provides enough current for your
    application. The Amp hour rating is listed on the 9.6 v battery and should be
    compared to the rating of the D cells. The worst thing that may happen is
    that you may have to recharge the 9.6 v battery more often.
    edited 2002-03-30 06:05
    What is the amp rating of a D cell?
    edited 2002-03-30 08:10
    Can be from 1.2Ahrs - 4Ahrs (1.2v nominal cell voltage) .
    Rob
    From: Matt Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1ff0WmHZKZLky4kNSXMPgfFLJ3SOzr76Y8UtxnXv-CyX7Z1I0wT7rZvv7h9m31_uQIFvgV8]matt@m...[/url
    Sent: 30 March 2002 06:05
    Subject: Re: [noparse][[/noparse]basicstamps] Battery Question...
    problems
    your
    should be
    is
    edited 2002-03-30 14:06
    1500 mA i think
    Ben
    Matt Johnson <matt@m...> wrote: What is the amp rating of a D cell?
    from the same email address that you subscribed. Text in the Subject and Body of
    BEN (TEAM DBR)
    http://www.geocities.com/temdbr
    Do You Yahoo!?
    Get personalised at My Yahoo!.
    edited 2002-03-30 15:39
    edited 2002-03-30 17:50
    Look at the link:
    http://www.swssec.com/bat2.html
    and see if that answers your question..
    regards,
    Leroy
    Look at the link:
    regards,
    Leroy
    edited 2002-03-30 20:32
    Well if my 9.6v battery pack from radio shack is 1700 mah. How do you do
    the conversion to see how long it will last compared to 6 "D" size
    batteries?
    I dont know the consumtion rate of the radio, its a boom box.
    - Matt
    > Rob
    > From: Matt Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HqywVRrNvUEnhQi4tl9RYUHPvy1RFBBzJgtN9O-m_mzpEiHwjWfI63X9i1KNwswkrDAUrA]matt@m...[/url
    > problems
    > your
    > should be
    > is
    edited 2002-03-31 14:42
    If as stated by one the links, the Ah capacity of a "D" alkaline battery
    is 14.25 Ahrs and your NiCad is 1.7Ahrs. This equates to 1.7 / 14.25 =
    0.119 Therefore the NiCad will only last about a 1/10 of the time the
    alkaline will. The above is using generalizations about discharge rates
    etc, but will give you some idea. One point to bear in mind is that
    NiCad's "self discharge" in relatively short space of time. A few days
    of non use and capacity is starting to drop. The major (can be
    dangerous) characteristic of NiCad's, is that you can source extremely
    high currents over a short duration. So proper fusing needs to be used
    in case a short circuit occurs.
    Rob
    From: Matt Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tSoFtpi4q5U-XBgTaaomxoeoIl4yRxMBefQlOT5Chs7TIEk-h5PdAoXaZAFlq6RsCD5VoT_U]matt@m...[/url
    Sent: 30 March 2002 20:33
    Subject: RE: [noparse][[/noparse]basicstamps] Battery Question...
    batteries?
    - Matt
    > Rob
    > problems
    > your
    > should be
    happen
    > is
    Subject
    edited 2002-03-31 15:36
    I've not been paying much attention to this thread because I was confused
    from the start about what battery types were being mixed, etc., but I can
    comment on the point involving capacity - from a position of 30 years in
    the lead-acid battery industry.
    The capacity of a battery is dependent on the rate at which it is
    discharged. Assuming for a moment a "D" cell alkaline cell has a
    manufacturer's rated capacity of 14.25 Amp-hours and the NiCd in question
    has a capacity of 1.7 Amp-hours.... at a discharge rate of say 10 ma, the
    "D" alkaline cell will far outperform the NiCd. But in an application that
    demands a high current you could well find that the NiCd outperforms the
    alkaline. Why? The reasons relate to two things - the basic chemistry
    involved and that the alkaline cell has a higher internal resistance.
    When you pull a heavy current from the NiCd cell it's voltage drops very
    little as it delivers current until it's capacity is nearly exhausted, then
    the voltage drops like a rock tossed off a cliff. When you pull a heavy
    current from an alkaline cell the voltage drops immediately and then
    proceeds on a steady downhill slope as the discharge continues. At some
    point in the discharge of each cell the voltage will fall below the voltage
    needed to keep the device running and that's the end for both. Generally
    speaking, alkaline cells deliver more capacity then NiCds at low discharge
    rates and Ni-Cd outperforms alkaline at high discharge rates.
    Some of the battery manufacturers publish characteristic curves for their
    cells. These will allow you to predict performance at any discharge
    rate. You *CANNOT* just pick one capacity rating, say 14.25 AH for an
    alkaline "D" cell and apply that to assorted conditions involving varying
    discharge rates. You can't do it with Ni-Cd either, but Ni-Cd does come
    closer than alkaline to delivering a more consistent capacity at varying rates.
    An example of the characteristic curves that relate voltage to discharge
    rate over time are shown at
    http://data.energizer.com/batteryinfo/application_manuals/cylindrical_alkaline.h\
    tm
    The main site URL is http://data.energizer.com/ . Other manufacturer's
    sites are easy enough to find with a search at http://www.google.com
    This is what you need to use to predict performance. Don't forget to
    determine the minimum voltage for the device you're powering first - and be
    aware that a device that averages a draw of 100 ma, but has peaks of 500 ma
    can stop working suddenly when the battery is low and a peak load is placed
    on it that crashes the voltage. Also note that NiCd manufacturers tend to
    rate their cells down to 0.9 or 1.0 volts (minor difference since NiCds are
    failing fast at 1.0 volts), while Alkaline manufacturers seem to rate down
    to 0.8 or 0.9 volts. All that matters is your needs, and then compare
    those to the characteristic curves. The curves let you pick the cutoff
    voltage your device needs and predict capacity to that cutoff voltage.
    Jim H
    edited 2002-03-31 16:26
    What kind of fusing? how do I know what size fuse to put in? and do I do
    it inline with the red or black wire?
    - Matt
    > Rob
    > From: Matt Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-y7Y5NvGlKZM7wPgL5IcdJs_Ru2HNFDGJ5_8zpbt_azZhafOW6Z1QbkqPPskVVjffNCy6OR1nA]matt@m...[/url
    > batteries?
    > - Matt
    > > Rob
    > > problems
    > > your
    > > should be
    > happen
    > > is
    > Subject
    edited 2002-03-31 19:33
    In your last paragraph are you saying that I can ruin the boom box with
    the nicads? What can I do to protect the electronics against anyhting that
    may happen with the battery?
    - Matt
    rates.
    tm
    > Jim H
    edited 2002-03-31 20:14
    Hi Matt
    Just connect a fuse in line with the positive NiCad lead. A car stereo
    in-line fuse holder with a 2amp fuse should be OK.
    Rob
    From: Matt Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rR3oiVPV4OYikwi-oPZ0T67Y0t3gazVZwhKnjmM7Us10DEpBH9-EWp8I_UxgrhSa426Mn7cNwlc]matt@m...[/url
    Sent: 31 March 2002 19:33
    that
    - Matt
    battery
    rates
    days
    extremely
    used
    confused
    can
    in
    question
    the
    that
    the
    chemistry
    very
    then
    heavy
    some
    voltage
    Generally
    discharge
    their
    varying
    come
    varying rates.
    discharge
    kaline.htm
    manufacturer's
    and be
    500 ma
    placed
    tend to
    NiCds are
    down
    cutoff
    > Jim H
    edited 2002-03-31 20:33
    > that
    > then
    > voltage
    > varying rates.
    tm
    > and be
    > 500 ma
    > placed
    > are
    No, and I don't see any likelihood of damage to your boom box from using NiCds.
    Just understand that alkaline cells have a nominal voltage of 1.5 volts per
    cell and NiCds have a nominal voltage of 1.2 volts per cell, so you get
    less voltage from the NiCds from the start. But as you use the boom box,
    the NiCds will probably tend to hold their voltage over time better than
    the alkaline cells - especially if this is a big boom box that really eats
    batteries. The NiCds perform better under heavy loads. If I knew exactly
    how much current the boom box draws, and the brand of batteries you're were
    using, I could probably dig up the battery performance curves from the
    manufacturer's web site and make a more informed prediction. One catch - a
    lot of "D" sized NiCds are really only "C" sized NiCds in a "D" sized
    shell. If you think you need the real "D" cells, then compare the weight
    of the "D" NiCds to the same brand of "C" NiCd and if they're about the
    same, then they're really "C" cells hiding inside a "D" cell casing. Mfgrs
    do this because most folks don't need the extra capacity (and expense) of a
    true "D" NiCd.
    Like I said, I missed out on the beginning of this discussion so I may have
    missed something.
    Back to NiCds causing damage to some devices - yes this can happen. The
    circumstances under which it happens is when the performance of the battery
    in the device is limited by the internal resistance of the battery rather
    than the resistance of the device. This can be the case with some cheaper
    electronic flash units where the charging electronics can overheat because
    NiCds can deliver more current under heavy load than alkaline cells
    can. If you fire off a lot of shots one after another you could damage
    some cheap flash units. If this is likely, the directions will probably
    warn not to use NiCds. You can also damage a DC motor running on NiCds if
    you stall the motor. An alkaline cell may not be able to continue
    delivering all the current a stalled motor calls for, but a NiCd is able
    and it can burn out a stalled motor. If you don't stall the motor though,
    it's not a problem, though lower voltage could make the motor run slightly
    slower when it's lightly loaded.
    I hope that helps. Feel free to ask more questions if you want to, but
    beware I might have to ask for whatever earlier specifics I missed to
    answer them.
    Jim H
    edited 2002-03-31 23:03
    Speaking of Nicads, I've had really good luck with SR batteries.
    http://www.srbatteries.com/
    They make excellent batteries at reasonable prices. I'm not affiliated,
    just constantly amazed at the quality of the packs.
    Steve
    There's decent tech data at energizer.com.
    > Rob
    > From: Matt Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Xi6m1QrUIM4JpMpdro7rVXMO94C8qGT-Q3FHXXhzhZFqNE3Dgrk14W7E7BTw9pg3TuSEjqEs]matt@m...[/url
    > problems
    > your
    > should be
    > is
    Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
    Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
    email: lamont@a... WWW: http://www.serv.net
    "Do not fear mistakes, There Are None" - Miles Davis
