Serout -> Serin Turnaround time ?
Stampers,
Can anyone tell me the minimum amount of time a BS2 needs between the
last byte of a Serout transmission and being able to accept the first byte of a
Serin transmission on the same I/O pin -assuming the Serin command
immediately follows the Serout ?
I have this in my notes somewhere -but do you think I can find it ?
Is this 'turnaround time' 2.5 times less on the BS2-SX and BS2p modules,
due to their higher clock speed ?
-Mark
Mark@H...
-Mark
Mark@H...
http://www.emesystems.com/BS2rs232.htm
I would use a scope and a code loop to get precise timing
Radu
Thanks. I suspected Tracy might answer but I hadn't realized that he had so
much info on his site.....
-Mark
Mark@H...
