Beginner Serial Communication and Pin Out Question
I already have written a program in visual basic 6 on a PC that sends
various characters or character strings through the serial port. How
would i, depending on specific information sent, activate a pin and
make it output voltage until it reads in a second specific character
telling it to shut off. I am junior in high school who has just
purcahsed this BS2p24 and am very interested in these types of
things. I only know how to do very basic things so far, like blinking
an LED. I am hoping through perhaps these responses i will be able to
advance my understanding of this fine machine. Thanks a lot for your
help and time.
help and time.
If you look closely at the description of SERIN in the Help menu of
your Stamp Editor, you will find that you can wait for the occurence
of ANY character before clocking in any other data. If you are not
worried about TIME, you could configure SERIN to wait until the
character before THE CHARACTER IN QUESTION is sent to the Stamp and
clock in *only* THE CHARACTER IN QUESTION. After that you can do the
on/off control
Radu
> Hi,
occurence
the
> on/off control
> Radu
Thanks a lot for your help Radu, i will take a closer look at the
information you have mentioned, if anyone else has any other input i
would love to hear it.
The single best reference I have found for all things related to serial
communication is:
"The Serial Port Complete," by Jan Axelson.
Trust me, you need this book. It covers serial comms between PC's,
from PC's to microcontrollers, and between microcontrollers. Most of
her microcon examples are based on the Stamp, and all include source
code.
Good luck!
peter
>on/off control
>Radu
One trick that I'm using that seems to be working is getting 2 stamps
to talk to each other using the programming connector (one of the
stamps is inside the IFI Robot Controller and its the only "real"
port on the stamp I can get to).
Basically, I have a stamp acting as a peripheral processor for the
IFI's stamp, and it sends packets over the serial line on a fairly
regular basis. When the IFI stamp wants to grab a packet, it reads
bytes from the programming serial port.
To sync them, each packet starts with a $FF header, and no byte in
the fixed length packet can be $FF. The IFI Stamp does a serin with
a WAIT($FF), then reads in the data.
If the IFI Stamp starts reading in the middle of a packet, the start
and stop bits will ensure there is a 10 sequence in the bitstream,
and it won't see a $FF until the next packet comes in.
I think there is one pathological situation where it might see a
spurious $FF, let's see:
start bits are 0's, stop bits are 1's, so
start 0 1 1 1 1 1 1 stop
might be interpreted as a $FF if the serin interpreted the first data
0 as the start bit, and thinks the stop bit is a data bit (which
it'll interpret as a 1). This is complicated by the fact that the
interbyte sending delays imposed by the stamp (several bits worth at
9600 baud) will appear to be stop bits. But that's low probability
and can be caught by including a checksum (as long as it is not
allowed to be $FF, of course). It might be possible to deal with
this by using non-inverted logic, or alternately by using $00 as the
"start" byte.
In my particular application I'm sending a packet of 8 nybbles with
the 1111 value being illegal, so I'll never have to worry about such
a misframing. My peripheral stamp is doing it's thing, sending out
about 50 packets a second, and the IFI stamp can read as many of them
as it wants.
If anyone else has been playing with getting stamps talking to each
other using the programming connectors, I'd be obliged for any tips
and cautions you might want to offer.
Best,R
Woodhead's Law: "The further you are from your server, the more likely
it is to crash."
