problems with a mosfet
I am useing an n channel mosfet (International Rectifier irf730) to contorl
a fan, in my circut i have conected the gate to the stamp pin an a pull down
resistor, the sorce to ground and the fan to the dran to the neg of the fan
and positeve to +12vdc. i also put a diode reverced acros the fan to stomp
any voltage transenats. both +5 and +12 have the same gnd.
my problem is that i can control the fan, even if i tie the gate directly to
+5v or gnd, the fan just runs at about 50% and the mosfet really heats up,
is the fet fried? the gate threshold according to the data sheet is 2 to 4
volts. whats the deal?
Lincoln
Lincoln
>Lincoln
>Lincoln -
What is the amperage rating of the fan ?
Bruce Bates
Sounds like the fan is either defective (too much current required), the
RON of the MOSFET is too high, or as you say the FET is defective. If
the fan is OK (check it directly connected to a 12 v supply, and measure
the current draw). You could try multiple MOSFETs in parallel, to reduce
RON. My preference is the IRF540 device.
Rob
From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UglMumXfbG0tfDMKqioCgIGKKouBLH17uZYZjSEJQw-52ITMsk4LmTq2-rbhQ71Q0VH5UCdscNS_X7pMZM3t]bvbates@u...[/url
Sent: 20 March 2002 04:58
Subject: Re: [noparse][[/noparse]basicstamps] problems with a mosfet
contorl
down
fan
stomp
directly to
up,
to 4
>Lincoln
>Lincoln -
Bruce Bates
Your use of Yahoo! Groups is subject to
thanks
Lincoln
Sent: Tuesday, March 19, 2002 11:19 PM
Subject: RE: [noparse][[/noparse]basicstamps] problems with a mosfet
> Hi
> Rob
> From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ArgFPN7jBD0mhm8X0kFxbRQAH6Zxa4Tg7paD3Tpj7Cfz9ECsHW6WGIqNS2_-c8zg7omz2YhWO5AKmMw3Kw]bvbates@u...[/url
> contorl
> down
> fan
> stomp
> directly to
> up,
> to 4
> >Lincoln
> >Lincoln -
> Bruce Bates
