program stops to working
hi,
first of all, hello.
i m new to this list but i heard it is very newbie friendly here,
so i hope that my question will find some open ears.
i got my bs2 today and was interfacing it with a devantech ultrasonic
range finder, using more or less there example software.
i just modified it to write the value of the range via the
serial port to some software.
unfortunately, everytime i open the serial port for listening to the
stamp, the program stops, i know this because the silent ping of the ultra
sonic stops.
otherwise it is running fine and debug mode gives me the right ranges.
the problem with the serialport occuours under windows and linux.
anyone any idea ?
thx a lot in advance
erich
ps: here the code:
'{$STAMP BS2}
wDist var word
INIT con 0
ECHO con 1
convfac con 29 ' use centimeters
main
gosub sr_sonar_2
'debug dec wDist, cr
serout 16,9600,[noparse][[/noparse]dec wDist]
pause 200
goto main
sr_sonar_2:
pulsout INIT,5 ' 10us init pulse
output INIT ' dummy command (delay)
rctime ECHO,1,wDist ' measure echo time
wDist=wDist/convfac ' convert to inches
pause 10
return
sonic stops.
anyone any idea ?
erich
ps: here the code:
'{$STAMP BS2}
wDist var word
INIT con 0
ECHO con 1
main
gosub sr_sonar_2
pause 200
goto main
sr_sonar_2:
pause 10
return
Be sure your serial port DTR line is low or disconnect it.
A high DTR keeps the stamp in reset
Regards peter
Oorspronkelijk bericht
Van: rat@t... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9YSQDQstfa3jvxHv_3maamfluuPnCcLdQDGb-TsmxVKcxr9Qg-w5o6T1vhPTLYA22SDcjqqDRw]rat@t...[/url
Verzonden: maandag 18 maart 2002 01:22
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] program stops to working
hi,
sonic stops.
anyone any idea ?
erich
ps: here the code:
'{$STAMP BS2}
wDist var word
INIT con 0
ECHO con 1
main
gosub sr_sonar_2
pause 200
goto main
sr_sonar_2:
pause 10
return
