DS1307 Problem
I have a problem with the DS1307, I built the PCB for
the DS1307 with the PIC-N-LCD for LCD control so with
this card I have control of the LCD and the Real TIME
CLOCK. I get FF:FF:FF for time,, maybe is
interference or something wrong. I cut the tracks
that join the +5v from the circuit of the DS1307 and
the PIC-N-LCD and the DS1307 works perfect,, when I
use the same power supply I get wrong values or
garbage.... of someone know how to fix this,, I will
appreciate so much
Alejadnro Vazquez
__________________________________________________
Do You Yahoo!?
Yahoo! Sports - live college hoops coverage
http://sports.yahoo.com/
appreciate so much
Alejadnro Vazquez
Do You Yahoo!?
Are you using the battery backup function of the DS1307? I've found
that if you don't need the battery backup, the VBatt pin must be
grounded for it to work properly. I've been in the same boat as you:
seeing FF:FF:FF flash on the screen! Try grounding the pin and see if
it works.
Good luck,
--Jeff
Add a RTC, up to 256k EEPROM and an I2C buss to your BS2
www.high-techgarage.com/products/timekeeper3.php
> appreciate so much
> Regards,
> Alejadnro Vazquez
> Do You Yahoo!?
board.
Lincoln
Sent: Saturday, March 16, 2002 7:39 PM
Subject: [noparse][[/noparse]basicstamps] DS1307 Problem
> appreciate so much
> Regards,
> Alejadnro Vazquez
> Do You Yahoo!?
between a DS1307 with other circuit (shift register).
When I only use the power supply for the DS1307 i get
a perfect reading but when I share the power supply I
get a reading like this: FF:01:00 that increments 3 by
3 (very strange). I already try to use separte 7805
for each circuit but I get the same problem. If
someone knows how to fix it please let me know.
Alex
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
http://http://taxes.yahoo.com/
Eric
To: "Basic Stamp" <basicstamps@yahoogroups.com>
Sent: Tuesday, April 02, 2002 2:38 PM
Subject: [noparse][[/noparse]basicstamps] DS1307 problem
> Hello,, I have a problem sharing the power supply
> Thanks
> Alex
> Do You Yahoo!?
