Control 150 leds — Parallax Forums
Control 150 leds
edited 2002-03-15 23:00 in General Discussion
Hello,
I have a huge problem,,, I have to control with one
BS2 more than 120 LEDS Independitly. For example I
want to turn on the last (120) led at the same time
the first led (1), then I want to turn on all leds,,,
then the odds, then even, etc...etc... I need to have
control of each led independiently.
I have used a 8 bit binary serial driver (from allegro
UCN5821A that I think is similar to the 74HC595
Shiftregister) but you know I have to use 3 pins of
the BS2 for clock,data and strobe,,,, so with 16 pins
I only have control of 5 5821 with a total of 40 leds.
PLEASE HELP ME!!
Alejandro Vazque
__________________________________________________
Do You Yahoo!?
Yahoo! Sports - live college hoops coverage
http://sports.yahoo.com/
    edited 2002-03-14 20:21
    Hi Alejandro,
    Actually, with this setup, you can control 112 LEDs. Here's why:
    The clock and data lines are on the 3-wire bus; all devices can share
    the clock and data lines. The chip select's however need to go to the
    individual devices. You can use 2 stamp pins for DATA and CLOCK.
    Connect all of the data pins on the shift registers to the same stamp
    pin (DATA). Connect all of the clock pins on the shift registers to
    the same stamp pin (CLOCK). The remaining 14 stamp pins can then
    connect to each shift registers CS pin. (Then you can control 14x8 or
    112 LEDs). You use shiftout as you normally would; just make sure to
    use the correct CS to activate the shift register you need.
    That gets you closer, but still leaves you a little short.... You
    could use something like a MAX349 and cascade the last two devices
    together. The datasheet (page16, available at http://www.maxim-
    ic.com) shows how this is done. You would still have the same DATA
    and CLOCK, as well as the 14 CS lines. The only difference would be
    that the last MUX would be daisy chained together. That would give
    you the extra 8, for a total of 120.
    Hope this helps....
    --Jeff
    Add a RTC, 256k EEPROM and an I2C buss to your BS2, e, sx or p!
    http://www.high-techgarage.com/products/timekeeper3.php
    --- In basicstamps@y..., Alejandro Vazquez <alexvazquez@y...> wrote:
    > Hello,
    > PLEASE HELP ME!!
    > Regards,
    > Alejandro Vazque
    > Do You Yahoo!?
    edited 2002-03-14 20:23
    Alejandro,
    I've made large arrays where I controlled individual LEDs using the Toshiba
    TB62706BN. I get them through Marktech Opto but they may be available
    elsewhere.
    http://www.marktechopto.com/PDFs/Toshiba/ACF7BE.pdf
    These series of drivers (TB62706, TB62708, etc) have a serial output and
    can work with one data line, one clock line and signal latch line so you
    can have all the LEDs change together. You don't need limiting resistors
    with this driver and can set the current through a single current
    programming resistor to the chip. The remainder of the series can be
    found here:
    http://www.marktechopto.com/catalog/Catalog.cfm?Drill_Level=Series&DeptID=2100&S\
    eriesID=1286
    Good luck,
    At 11:56 AM 3/14/2002 -0800, you wrote:
    >Hello,
    >PLEASE HELP ME!!
    >Regards,
    >Alejandro Vazque
    >Do You Yahoo!?
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    Mike Walsh
    walsh@c...
    California Institute of Technology
    Biology Electronics Shop
    MS 216-76
    Pasadena, CA 91125
    626-395-6825 , FAX 626-584-1654
    237 Beckman Behavioral Biology Bldg.
    edited 2002-03-14 20:31
    Hello Alejandro,
    After reading Gene's suggestion (which is much, much simpler than
    what I originally proposed), I remembered Maxim's MAX7219/MAX7221.
    This device can control up to 8 7-segment LEDs or 64 individual LEDs.
    This would only require 3 stamp pins (Data, clock and CS). Page 13 of
    the data sheet shows how they can be cascaded. You can probably get
    samples of this chip from Maxim's website.
    If you need help with the software, I have a tutorial for the MAX7221
    at: http://www.high-techgarage.com/tutorial/max7221.php. You will
    also find a link to the datasheet there.
    Good luck,
    --Jeff
    A RTC, 128k EEPROM and an I2C bus in a tiny SIP package!
    http://www.high-techgarage.com/products/mightymite.php
    > Hello,
    > PLEASE HELP ME!!
    > Regards,
    > Alejandro Vazque
    > Do You Yahoo!?
    edited 2002-03-14 20:53
    Gene,
    Maybe the MM5451? Last time I tried, I couldn't find them anywhere. Are
    they still available?
    At 01:33 PM 3/14/2002 -0800, you wrote:
    >I don't recall the chip number off the top of my head, but Natsemi makes a
    >7 segment display driver that will drive 33 individual LEDS via a 3 wire
    >SPI interface. They can be daisy chained to accomodate your requirement.
    >g.
    Mike Walsh
    walsh@c...
    MS 216-76
    Pasadena, CA 91125
    edited 2002-03-14 21:33
    g.
    On Thu, 14 Mar 2002, Alejandro Vazquez wrote:
    > Hello,
    > PLEASE HELP ME!!
    > Regards,
    > Alejandro Vazque
    > Do You Yahoo!?
    "I'm not crazy, I'm plausibly off-nominal!"
    http://www.f15sim.com - The only one of its kind.
    edited 2002-03-14 21:56
    At 11:56 AM 3/14/02 -0800, Alejandro Vazquez wrote:
    >Hello,
    How fast do the LEDs have to update? How much current are you operating
    the LEDs at?
    If the update rate is slow and you are operating the LEDs at 5 to 10 mA,
    you can use a string of 74HC595 shift registers. 3 wires from the Stamp is
    all that is required. If you need more current than the hc595s can sink,
    use TPIC6C595 (same pinout as hc595) or TPIC6595. These are good for up to
    100 mA or 250 mA respectively. Use sinking mode for the LEDs: anode to
    Vled via the current limit resistor, cathode to the SR pin. I generally
    use about 4 Vdc as the LED supply - you may want to reduce that to 3.3V to
    reduce the total power dissipation. Be sure to run the HC595s from the 5V
    supply - they need 5V or higher to ensure the output FET drivers are fully
    enhanced.
    If you need more speed, split the chain into as many serial streams as
    required. You can share the clock and latch lines for all streams, with a
    separate data line for each stream. But if you are trying to get really
    fast update rates, the stamp is not the right tool for the job.
    I drive 2 streams of 128 LEDs on one of our Pyro controllers with an update
    rate of 5 milliseconds (not by a stamp, though). I could have gone longer
    if I needed - 256 LEDs in 1 data stream is no problem at all.
    dwayne
    Dwayne Reid <dwayner@p...>
    Trinity Electronics Systems Ltd Edmonton, AB, CANADA
    (780) 489-3199 voice (780) 487-6397 fax
    Celebrating 18 years of Engineering Innovation (1984 - 2002)
    Do NOT send unsolicited commercial email to this email address.
    This message neither grants consent to receive unsolicited
    commercial email nor is intended to solicit commercial email.
    edited 2002-03-14 21:58
    That's a neat part Jeff. Thanks for the info. What I don't get is how
    they can drive 64 LEDs from a 24 pin chip. The National part I'm thinking
    of is a 40 pin package and only drives 33 (or 35, I don't recall
    exactly) LEDs. Are they tieing all the cathodes together or something?
    g.
    edited 2002-03-14 22:26
    On Thu, 14 Mar 2002, Mike Walsh wrote:
    > Gene,
    > Mike
    YEs, that's the one. They're also made by another company (548?) and I
    recently bought a bunch of them from Pioneer. I'm at work so I don't have
    any of my notes handy.
    g.
    edited 2002-03-14 23:03
    The MAX 7219 can come to the rescue. I think the data sheet says it can
    control 64 separate LED's (or 8 - 7 segment displays). I have not used it
    this way. You could use 2 chips for 128 LEDs or 3 for 192 LEDs. You just need
    4 I/O lines for 2 chips and 5 lines for 3 chips (or get fancy and 4 lines and
    a NAND gate for 3 chips)
    I am not near a data sheet (on the road) so I cant help anymore until next
    week.
    Alan Bradford
    Plasma Technologies
    edited 2002-03-14 23:06
    I almost forgot! The MAX 7219 can be chained together to allow many chips to
    be driven from the same data line. It has a data out pin. The spec sheet
    shows this. That way 3 I/O pins are all you need
    Alan Bradford
    Plasma Technologies
    edited 2002-03-14 23:50
    Hi Gene,
    > What I don't get is how they can drive 64 LEDs from a 24 pin chip.
    The MAX7219 can control 64 LEDs because there are essentially 8
    segments in a 7-segment display (the 8th is the decimal point). The
    chip can control 8 digits. Therefore, there are 8 discrete LEDs per
    digit, or 64 discrete LED's than can be lit.
    -A-
    F| |B
    -G-
    E| |C .DP
    -D-
    The datasheet for the MAX7219 explains this concept in a little more
    detail. (You can download a copy from the "support" section of our
    website, or go to www.maxim-ic.com and search for MAX7219).
    --Jeff
    Check out our Basic Stamp tutorials:
    edited 2002-03-15 00:02
    I thought it was because it was scanned.
    On Thu, 14 Mar 2002, bs2web wrote:
    > Hi Gene,
    > -A-
    > F| |B
    > -G-
    > E| |C .DP
    > -D-
    > --Jeff
    Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
    Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
    email: lamont@a... WWW: http://www.serv.net
    "Do not fear mistakes, There Are None" - Miles Davis
    edited 2002-03-15 00:29
    Alejandro,
    The part you most definitely need is the Allegro UCN5833. It's a serially
    controlled 32-bit shift register that's about $6, and couldn't be simpler to
    communicate with. You can chain multiple units together. I used it in one
    of my recent projects, in which I had to control 8 7 segment scoreboard
    digits:
    http://www.weatherstamp.com/parnelleng/images/scbddrvr01.jpg
    The additional chips on this board are Allegro 2940s, which are used to sink
    the additional current required by each segment. Each "segment" consists of
    3 100 mA 14V bulbs.
    The datasheet for the UCN5833 is here:
    http://www.allegromicro.com/sf/5833/
    Matt Parnell
    mail@w...
    Parnell Engineering, LLC Main: 734 464 0150
    http://www.weatherstamp.com Fax: 734 432 9866
    37637 Five Mile Rd., #198 Pager: 517 251 7674
    Livonia, MI 48154-2634 USA Cell: 734 347 3998
    From: Alejandro Vazquez [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kG5UaTRVdludSb3M53XDTVZ-KwXerjGk4Ol78JSoLknRscbpgFjZMF1FjpPgs_V6RpX5BtXeWMtKbKUG90w0]alexvazquez@y...[/url
    Sent: Thursday, March 14, 2002 2:57 PM
    Subject: [noparse][[/noparse]basicstamps] Control 150 leds
    Hello,
    PLEASE HELP ME!!
    Alejandro Vazque
    Do You Yahoo!?
    edited 2002-03-15 02:34
    www.alegromicro.com has a number of LED drivers I am partial to.
    Plus with the right words they'll send you some samples too.
    A6276ELW is a 16 output serial input driver.
    UCN5832A and UCN5833A are both 32 output serial in/out drivers. Easy to
    cascade these.
    They also have a bunch of other drivers 7 bit and 8 bit outputs, et cetera
    as well.
    The 32 bit ones were a lot of fun to use. One serial output port, four chips
    cascaded gave me 128 output lines. Up to 3.3 mhz serial data rate (a lot
    faster than the Stamps can go). Basically, you disable the outputs, then you
    load the registers with the data, and then enable the outputs. You do this
    rapidly many many times a second.
    From: Alejandro Vazquez [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=x584yLFvBc3iO_s9ub3BUq4Sp8MLfstGlFCC9ti0IVoSdQdEZn7bIyckmKPdg4d6LeELFSfGR5WPARvzPax7oA]alexvazquez@y...[/url
    Sent: Thursday, March 14, 2002 1:57 PM
    Hello,
    PLEASE HELP ME!!
    Alejandro Vazque
    Do You Yahoo!?
    edited 2002-03-15 14:43
    Dear Matt,
    Thanks for your help,,,
    I have a question---- the BS2 is a 16 bit micro how
    can I comunicate with a 32 bit device?
    Ok so,, I can have control of 160 leds with 5 5833,,,
    independiently but how can I connect in chain multiple
    units,, do I still have control of each led?
    Alejandro Vazquez
    --- Matt Parnell <mail@w...> wrote:
    > Alejandro,
    > segment scoreboard
    > digits:
    > 3 100 mA 14V bulbs.
    > Matt Parnell
    > mail@w...
    > [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-d8iOGOH7mKkCjLJ4wwalP6EBERa4r02ex8_idD1ZWSKfLkO2FiUlsq2Hq64u9fvUjb3NoHHzWRCjs8arCe5]alexvazquez@y...[/url
    > Hello,
    > leds,,,
    > have
    > allegro
    > pins
    > leds.
    > PLEASE HELP ME!!
    > Regards,
    > Alejandro Vazque
    > Do You Yahoo!?
    > Text in the Subject and Body of the message will be
    > ignored.
    Do You Yahoo!?
    edited 2002-03-15 14:58
    At 06:43 AM 3/15/2002 -0800, you wrote:
    >Dear Matt,
    >Alejandro Vazquez
    Alejandro -
    You can download the UCN5833 data sheet from this link:
    http://www.allegromicro.com/sf/5833/index.htm
    In the data sheet or on the web page you will see this device accepts SERIAL
    INPUT, so the number of "bits" is not significant.
    Hope that helps.
    Bruce Bates
    edited 2002-03-15 16:20
    On Fri, 15 Mar 2002, Alejandro Vazquez wrote:
    > Dear Matt,
    The key in his description was that it is a "serially
    controlled" device. This means that it sets each of the 32 bits based
    upon a serial data stream entering the chip via (most likely) a 3 wire SPI
    interface.
    g.
    Hurrah !! After months of bugging people for stuff on this list and not
    being able to give anything back. Finally I may be able to be of some small
    assistance to someone.
    This chip works by tying the anodes of all the LEDS together, So for
    instance led 1 and led 8 have the same anode but different cathodes. The
    cathodes are then scanned while the appropriate data is output to the
    anodes. Which means that 64 leds can be driven from a 16 pin's.
    Now as long as the LEDS are being viewed by humans there is no problem the
    scanning frequency is high enough for them not to notice the scan. Film
    cameras are a very different proposition (as are video cameras but for a
    different reason). If you intend to film them then you will need to sync
    the clock rate of the chips with a separate source. (this is very easy as
    long as you are prepared and of course if you need to do this just ask[noparse]:)[/noparse]
    Justin Pentecost
