Bi Directional Serial Buse Problems (MORE DEAD STAMPS......)
Hi All,
I have built a bi directional data bus for communication between to stamps with
flow control.
The problem is that occasionally one of the stamps will die and refuse to
communicate serially any more. Nothing is shorting, each is in a nice PCB in a
simple circuit.
It looks like it's the flow control pin that is dieing in each case. What I am
wondering is whether it is possible to protect each stamp pin (flow control and
serial data) for each stamp without effecting the data. As each stamp is in a
different portable box, it is necessary to protect each stamp individually.
Can I do this...
BS2E FLOW PIN
RESISTOR
RESISTOR
BS2E FLOW PIN
BS2E SD I/O DATA
RESISTOR
RESISTOR
BS2E I/O DATA
ONE BOX |
THE OTHER BOX
I don't want to go for an optocoupler, unless it's absolutely necessary, as I
have never used one and it would require MAJOR redesign of my PCB. Besides, not
sure how u would make a bi-directional optocoupled bus.
If the resistor method works, what values should I use?
Any help appreciated,
Dwain
flow control.
simple circuit.
Can I do this...
BS2E FLOW PIN
RESISTOR
RESISTOR
BS2E FLOW PIN
BS2E SD I/O DATA
RESISTOR
RESISTOR
BS2E I/O DATA
ONE BOX |
THE OTHER BOX
Dwain
dwainsworld@e... writes:
> Hi All,
> with flow control.
> in a simple circuit.
> am wondering is whether it is possible to protect each stamp pin (flow
> control and serial data) for each stamp without effecting the data. As each
> stamp is in a different portable box, it is necessary to protect each stamp
> individually.
I have never done "flow control" but an easy way to isolate one stamp from
the other is using opto-isolators. Just off the top of my bald head, I would
think that one of the considerations is the speed at which you are sending
data. The opto isolator can turn on then off only so fast.
Ken
Or just until you cycle power?
2. Yes, tieing two Stamp pins together can have
the effect of tieing two drivers together, IF they
are both Outputs at the same time. IF one tries
to drive to 0, AND one tries to drive to +5,
you'll have a short through the drivers (for a
a very short time) and one
can burn out. The simple fix for this is to
(as you suggest) put some serial resistance in
the line to reduce the current. Values can be
220 to 1000 ohms, and yes, they can be spread
across multiple boxes. You also might want to
put the Flow pins in INPUT mode when not being
used for a message.
3. IF you are using SEROUT/SERIN (as you imply)
then you can use the 'Open Collector' mode. This
lets the 'bus' line float high (through a 10K
resistor to +5) and only drives low, so you never
have two drivers in opposite states.
4. #3 does not help for the flow control pin,
so yes, putting the separate serial resistors
on the flow pin(s) will work. I've been told
they may slow down transitions -- but this is
the Stamp we're talking about, it works very
slowly compared to wire signaling rates.
--- In basicstamps@yahoogroups.com, "Dwain J. Hill"
<dwainsworld@e...> wrote:
> Hi All,
stamps with flow control.
refuse to communicate serially any more. Nothing is shorting, each is
in a nice PCB in a simple circuit.
case. What I am wondering is whether it is possible to protect each
stamp pin (flow control and serial data) for each stamp without
effecting the data. As each stamp is in a different portable box, it
> Can I do this...
> BS2E FLOW PIN
RESISTOR
RESISTOR
BS2E FLOW PIN
> BS2E SD I/O DATA
RESISTOR
RESISTOR
BS2E I/O DATA
