moving from breadboard to pc board
I have constructed and programmed a tachometer on the BOE breadboard. It works.
On a perf board from Radio Shack, I re-created the circuit, and transferred the
Stamp and another IC, a digital
pot, from the breadboard to sockets on the perf board.
Not surprisingly, perhaps, the tachometer doesn't work in it's new incarnation.
To make sure I hadn't ruined the
chips in my "smoke test," I transferred them back to the breadboard. The
tachometer circuit still works fine.
The pc board is clean, no shorts, all wiring checks out.
What are the differences between the pc board version and the breadboard
version?
The pc board relies on the stamp's on-board regulator to produce a +5 supply for
the other chip. A check with the
VOM shows it is delivering the +5 supply okay.
The BOE has a serial interface -- the pc board has none. In other words, the
pins that were used for programming
are no longer hooked up to anything. Could this make a difference somehow? I
doesn't seem like it should, but I
am trying to exhaust the possibilites.
Thank you for your insights.
Michael
version?
Michael
A few things to check for.
First, how much current is the rest of your circuit drawing? The Stamp's
regulator can't provide much current and the more voltage you put in,
the less current you can get out (like most regulators).
Second, breadboards are big capacitors and so you might need bypass
capacitors on the PCB that you didn't need on the breadboard.
Third, have someone else check your wiring ;-)
Fourth, what other circuits are you using on the PCB?
Fifth, if your wiring rings true with an ohmmeter, I guess this isn't a
problem, but I have found that the Radio Shack boards are uniformly
filthy when you unpack them and a good fluxing (can I say that before
9PM?) will really improve their solderability.
If you have noisy things like motors or spark plugs nearby, you might
want to read the Stamp FAQ article about reseting the processor
spuriously. The FAQ is at http://www.al-williams.com/wd5gnr/stampfaq.htm
-- If you build your breadboard circuit and remove the programming cable
does it still work? It should.
Another problem that sometimes manifests itself as a "works with cable
on, not with cable off" is when you have a ground missing. Then you wind
up grounding your circuit through the DB9 and the PC. If you have
sensors, motors, etc. be sure the grounds are tied together.
Al Williams
AWC
* Control 8 servos at once
http://www.al-williams.com/awce/pak8.htm
> From: Michael Gianturco [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MrjBLxMsWwtswxdePn6EQWgIqpCkfWIFasfO-Rq54-wpnYjywkAktdfizJhpTv5AFvpI2MZK3Vk5DLPhIQ]michcg@m...[/url
> Sent: Wednesday, March 13, 2002 5:22 PM
> Subject: [noparse][[/noparse]basicstamps] moving from breadboard to pc board
> and transferred the Stamp and another IC, a digital pot, from
> it's new incarnation. To make sure I hadn't ruined the chips
> breadboard. The tachometer circuit still works fine.
> breadboard version?
> produce a +5 supply for the other chip. A check with the VOM
> other words, the pins that were used for programming
> difference somehow? I doesn't seem like it should, but I
> Michael
> from the same email address that you subscribed. Text in the
>the pins that were used for programming are no longer hooked up to
>anything. Could this make a difference somehow? I doesn't seem like it
>should, but I am trying to exhaust the possibilites.
I may be out to lunch here, but is MCLR included in those programming
pins? If so, it needs to be tied HI to ensure the micro runs.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
This is a BS2.
On the BOE, the pins numbered 1,2,3 are wired to the serial plug. They are,
respectively, Sout, Sin, and ATN. Sout
and Sin are probably short for Serial Out and Serial In. The ATN, I don't know.
It connects to a pin on the
serial plug via a .1 microFarad capacitor.
What is MCLR?
Many thanks, Michael
> dwayne
It was not in the board, after
all, but in my connection to the Hall Detector.
I cleaned the perf board with a rubber eraser, but if I use one again I might
try the "good fluxing." I am
comfortable with a soldering iron, usually, but this particular pc board did not
go very well. Maybe it was the
board.
Incidentally, I really enjoyed reading your book and I return to it again and
again for reference. You have an
excellent writing style, very helpful. I also enjoy your wry wit. Thank you
again for your help. Best, Michael
Al Williams wrote:
> Hi Michael,
> Al Williams
> AWC
> > From: Michael Gianturco [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aDZcrFoNrf0cJmNGNcch2uEIaBG7Q4R1u766DASyOemUpdiiCvOXLvQMEmiaWithDe9R81wMNy8TO_6zgbSFxA]michcg@m...[/url
> > breadboard version?
> > Michael
I have been waiting for someone like this to get some feedback
regarding my problem, however the problem manifests in reverse for
me, works with cable off not with cable on
cable
you wind
Radu
My ex son in law taught me the value of keeping those flux pens around.
His favorite trick was to cut strips of solder braid, soak them in flux,
and use them to soak up solder.
Another interesting flux related note. I recently picked up a few of
these "solder tinner cleaners" that you can get from Kester or Radio
Shack. I thought, what's the big deal? Turns out, they are amazing. Your
tip comes out very clean and shiny. They say lead free, so I don't know
exactly what's in them. Looks like a grey stone but sort of soft. These
aren't the old "cleaners" that were just a bunch of coils that would
scrape the iron, but something different.
Anyway, glad you enjoyed the book and that your project is working.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: Michael Gianturco [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lztORZjCDy-XKDPX1LYQWFlmIf48Iso5IDVa_8LUqDdC4pjrEZdHG4amAga2d_LkJDYlkfdL1OrgdDxpEg]michcg@m...[/url
> Sent: Thursday, March 14, 2002 8:49 PM
> Subject: Re: [noparse][[/noparse]basicstamps] moving from breadboard to pc board
> Thank you for you suggestions, Al. I think I have finally
> isolated the problem. It was not in the board, after all,
> one again I might try the "good fluxing." I am comfortable
> did not go very well. Maybe it was the board.
> to it again and again for reference. You have an excellent
> Thank you again for your help. Best, Michael
> Al Williams wrote:
> > Hi Michael,
> > Stamp's regulator can't provide much current and the more
> voltage you
> > put in, the less current you can get out (like most regulators).
> this isn't
> > a problem, but I have found that the Radio Shack boards are
> uniformly
> that before
> you might
> programming cable
> with cable
> > wind up grounding your circuit through the DB9 and the PC.
> If you have
> > Al Williams
> > AWC
> > * Control 8 servos at once http://www.al-williams.com/awce/pak8.htm
> > > transferred the Stamp and another IC, a digital pot, from the
> it's new
> > > incarnation. To make sure I hadn't ruined the chips in my "smoke
> > > test," I transferred them back to the breadboard. The tachometer
> > > breadboard version?
> produce a
> > > +5 supply for the other chip. A check with the VOM shows it is
> In other
> > > words, the pins that were used for programming are no
> longer hooked
> > > Michael
> the Subject
connections.
At 02:56 PM 3/15/02, you wrote:
>Hi
>Radu
